I am using mini2440 kit with 3.5" TFT. I have connected the Serial and USB cables to it and started in NOR flash booting. Then as per the manual I tried to install the USB Download driver for windows with "H:\windows平台工具\usb下 载驱动\FriendlyARM USB Download Driver Setup_20090421.exe", it actually throws the error as "Microsoft Visual C++ Runtime Error, abnormal program termination". Need help to overcome this error, so that I can use DNW for downloading any application to the kit. Your flashing response will be highly appreciated... Thanks in advance.. Regards, Arumugam R
Not able to install USB driver and DNW
Did you try to install the driver manually? Here are the driver/inf files: http://www.friendlyarm.net/dl.php?file=usb-downloaddr_20090421.zip
Hi Arul The issue is because you are trying to install directly from the CD. Copy it to your local hard disk and run the installation from there. It worked for me.
