Hi, Is the S3C2440 IP blocks available somewhere on this forum? I need to program the interrupts for the UART which uses DMA for xmodem transfer. I couldn't find the IP blocks of peripherals.
Mini 2440 IP blocks
I am guessing that you want to know the the UART control register names for various functions. You could try page 11-12 in the S3C2440.pdf found on the Downloads page.
The UART control registers are documented correctly but there is some more missing information like the Baud rate calculation, Interrupt association which are missing in the S3C2440.pdf is there any other document where i can get this information?
