I've got a working buildroot system on sd-card but are working to get it on
flash.
Somehow I seem to forgot something in my kernel config since there is no
/dev/mtdblock* device present, can someone help me out on selecting the
proper kernel drivers?
Uncompressing
done, booti.
Linux version 2.6.32.2-bfs-FriendlyARM (root@ubuntu) (gcc version 4.4.4
(Buildroot 2010.08) ) #13 PREEMPT Sun Feb1
CPU: VIVT data cache, VIVT instruction cache
Machine: FriendlyARM Mini2440 development board
CPU S3C2440A (id 0x32440001)
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: root=/dev/mtdblock3 rootfstype=jffs2
console=ttySAC0,115200
PID hash table entries: 256 (order: -2, 1024 bytes)
Memory: 64MB = 64MB total
Memory: 62188KB available (2340K code, 262K data, 80K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:85
irq: clearing pending status 02000000
console [ttySAC0] enabled
devtmpfs: initialized
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
bio: create slab <bio-0> at 0
s3c-i2c s3c2440-i2c: slave address 0x10
s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.13)
msgmni has been set to 121
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered (default)
Console: switching to colour frame buffer device 100x30
leds initialized
Hello, Mini2440 module is installed !
buttons initialized
pwm initialized
adc initialized
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
loop: module loaded
s3c24xx-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns
s3c24xx-nand s3c2440-nand: NAND soft ECC
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V
8-bit)
Scanning device for bad blocks
Bad eraseblock 552 at 0x000004500000
Bad eraseblock 952 at 0x000007700000
Creating 5 MTD partitions on "NAND 256MiB 3,3V 8-bit":
0x000000000000-0x000000040000 : "supervivi"
0x000000040000-0x000000060000 : "param"
0x000000060000-0x000000560000 : "Kernel"
0x000000560000-0x000040560000 : "root"
mtd: partition "root" extends beyond the end of device "NAND 256MiB 3,3V
8-bit" -- size truncated to 0xfaa0000
0x000000000000-0x000040000000 : "nand"
mtd: partition "nand" extends beyond the end of device "NAND 256MiB 3,3V
8-bit" -- size truncated to 0x10000000
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: S3C24XX OHCI...stripped-down
