Hello, i have a weird behaviour when using the SPI0 port on the Mini2440 with linux. Everthing worked fine , but since today the SPI clock ( GPE 13) is broken somehow. I`m not sure if this is a hardware or software fault, but when i power on the board, the SPI-Clock Pin goes to high and remains high, no matter what im trying to do. It remains high even when i try to use it as a regular GPIO. I can try to set its value, but with no effect. The SPI data and chip-select pins are working, when i send some data, only the clock-pin does nothing else but staying at high. any ideas what the problem is ? Or is the cpu damaged somehow ? Thanks Daniel
