Now I use a Debian distro by NFS filesystem (about 600Mb), but I want to put it on NAND (1Gb) and boot directly without NFS. Anyone know the right detailed procedure? Thanks in advice!
Write OS on NAND
Ps. the architecture is mini 2440 - 64Mb ram, 1Gb NAND z_image Kernel 2.6.32 by friendly arm uploaded from supervivi
Ok, first you make an tar archive of your rootfs... then boot, using nfs or an sd with your rootfs AND the tar archive of your rootfs then use "flash_eraseall -j /dev/mtd3" to clean the rootfs partition and create a jffs2 file system. then mount "mount -t jffs2 /dev/mtdblock3 /mnt" then copy the tar archive to the flash "cp myrootfs.tar /mnt" move to /mnt extract "tar xf myrootfs.tar" "sync" reboot change your u-boot bootargs to something like rootfs=/dev/mtdblock3 rootfstype=jffs2 i don't know how to do that with supervivi, but all's here guy. have fun, Zogzog.
Ok.. :) I've done a similar thing before the answer and it works! Thanks so! ************************************** Now I've an other problem: ************************************** load Image of Linux...Uncompressing Linux... ran out of input data -- System halted
