Can you plz describe how this switch works? As i see in table 3-1 in s3c6410 user manual if OM[4:0] = 1111x, IROM boot is selected. If GPN[15:13] = 000, IROM boots from SD/MMC ch 0. As i see in schematic this is one position of S2 switch. In another position of S2 it pulls OM3 & OM4 to gnd. So OM[4:0] = 00110. As i see in User Manual this is reserved combination. So i wonder how it is booted from nand? And how it boots from SD? I get it work booting from NAND with last git version of u-boot. Now i try to create small (<8K) bootloader to start u-boot from SD, but SD-Flasher won't flash my bootloader, becouse image is to small. I also try uboot_writer (with i was using wirh s3c2416), but SD card won't boot.
Mini6410 nand/sd boot switch
I found this page. It described what you want to known. http://blog.csdn.net/nanjianhui/article/details/4230565 The first picture is for s3c6410, the second picture is for s3c6400.
I am studying mini6410 board and
Mini6410 schematics and s3c6410 data sheets seems to be bit confusing.
Mini6410 SC36410 S1_ON S1_OFF
SELNAND XSELNAND 1 1
OM4 XOM4 0 1
OM3 XOM3 0 1
OM2 XOM2 1 1
OM1 XOM1 1 1
OM0 XOM0 0 0
BOOT_EINT15 XEINT15/GPN15 0 0
BOOT_EINT14 XEINT14/GPN14 0 0
BOOT_EINT13 XEINT13/GPN13 0 0
DBGSEL XDBGSEL 1 1
From s3c6410 datasheet
OM[4:0]
S1_ON = 0011 RESERVED
S1_OFF = 1111 SD/MMC
Why S1_ON setting seem to be reserved, as it should configure NAND? Is
there a problem with schematics?
I found also this: http://www.friendlyarm.net/forum/topic/2802
Hi, Somebody thinks certain configurations are "reserved" because Samsung wants to hide something, maybe better description of boot settings can be found from s3c6400 data sheet? Google translated article about booting s4c6410: http://translate.googleusercontent.com/translate_c?hl=en&rurl=transl...
