while booting from micro2440 we are getting like this please give me the
solution
load Image of Linux...Uncompressing
Linux.......................................
Linux version 2.6.32.2-FriendlyARM (root@russell-work-pc) (gcc version
4.3.2 (S0
CPU: VIVT data cache, VIVT instruction cache
Machine: FriendlyARM Mini2440 development board
ATAG_INITRD is deprecated; please update your bootloader.
CPU S3C2440A (id 0x32440001)
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: noinitrd root=/dev/mtdblock3 init=/linuxrc
console=ttySAC0
PID hash table entries: 256 (order: -2, 1024 bytes)
Memory: 64MB = 64MB total
Memory: 59560KB available (4676K code, 469K data, 160K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:85
console [ttySAC0] enabled
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
bio: create slab <bio-0> at 0
SCSI subsystem initialized
s3c-i2c s3c2440-i2c: slave address 0x10
s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
cfg80211: Calling CRDA to update world regulatory domain
TCP reno registered
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
yaffs Jun 9 2010 11:25:12 Installing.
msgmni has been set to 116
alg: No test for stdrng (krng)
io scheduler noop registered (default)
Console: switching to colour frame buffer device 30x20
backlight initialized
4.3.2 (S0
console=ttySAC0
failing to boot
Seems to be a problem with your power supply, because the board makes a reset after the display back light is switched on.
