Hello, I am trying to make the catalog working. Currently the catalog, i think, is just showing item. You can edit the catalog with VisualStudio just by clicking on the file in PLATFORM\CATALOG. There you can set sysgen variable. When an item is checked this wil result in VARIABLE=1. When, for example, SPI is checked, then will BSP_DRV_SPI=1 be set. This instead of Mini2440.bat, where you set BSP_NOSPI=1 if you DO NOT WANT the item. In platform.reg, .bib, .dat this variables can be used. For [sources] and [dirs] files i have not yet a solution that works. Anyway, just sharing this. See also http://robin.jansman.info:5980/?page=bspmini2440_ce6. Met vriendelijke groet, Robin
Mini2440 BSP Catalog
Forgot to say that if anyone is interested i will publish needed files. BSP based on http://code.google.com/p/friendlyarm/wiki/EnglishBSP .
