Hi guys, i tried the BSP for CE6 and works fine, but where i can find the english version ? thank you
WinCE6 english
Hi. If you are able to build it successfully, you can change the language from the options of the project. You see it when you right click at the project in solution explorer. Rebuilding will be required after you change the language. If you can help me to build win ce 6.0 image i'll be appreciated. I couldn't make it build. It always gives errors.
Hi I can't download wince6.0 image (there's wrong URL: when I click on wince6 images goes to http://www.arm123.com.cn/download/StartLogoMaker.rar and makes not found error ) If anybody how has English wince6.0 images upload it, I'll really appreciate it.
Hi, so, i install this file nk_t35 in my mini2440, and the windows is started, but when i restart the board, the image of wince dont't start again.
Hi Birlan, You need to install newer version of the supervivi with the jtag. http://www.friendlyarm.net/dl.php?file=download.pdf And the new supervivi can be found in the BSP; http://www.friendlyarm.net/dl.php?file=wince6-bsp_20100106.zip After use also the new uboot from this zip file.
Hi Edje11, We read the help in your document but we have some errors: + When we press f for format NAND flash, we receive this message: ................................................................................ ................................................................................ .................................... ... failed + After Download NK.bin, the KIT have restart and boot into WinCE6, we power off and set mode in S2: NAND and power on. We receive an message: load Windows CE Image.. and KIT hang up on this step. Please help me!
Is there anybody who can upload an English WindowsCE6.0 image for the Mini2440 with A70 LCD? All those I've found are in Chinese! Thank you very much in advance!!!
