Hello all, I am trying to use a rootfs baked with openembedded and kernel on my 1GB board. I have succesfully installed uboot on it. (I have created the bbt, everything is fine.) nand info said: Device 0: NAND 1GiB 3,3V 8-bit, page size 2048, sector size 128 KiB According to it I have changed the EXTRA_IMAGECMD_jffs2 value to "--pad --little-endian --squash -s 0x800 -n -e 128KiB" I have generated the image and I have placed it to an sd card: I have written it to the NAND trough the uboot in the following way: mmcinit fatload mmc 0:1 0x32000000 rootfs.jffs2 nand erase rootfs nand write.jffs2 0x32000000 rootfs $(filesize) And then I have set the following enviromental variables:ű setenv bootcmd nboot.e kernel \; bootm setenv bootargs root=/dev/mtdblock3 rootfstype=jffs2 console=ttySAC0,115200 mini2440=1tb roo saveenv After it it starts to boot, but it hangs with: mmcblk0: mmc0:45ed SD02G 1.91 GiB mmcblk0: p1 jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x3fa6001c: 0xffff instead Empty flash at 0x3fa60020 ends at 0x3fa600ac jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x3fa600ac: 0xfff3 instead Empty flash at 0x3fa600b0 ends at 0x3fa60500 jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x3fa60500: 0xfcff instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x3fa8001c: 0xffff instead Empty flash at 0x3fa80020 ends at 0x3fa800ac jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x3fa800ac: 0xfff3 instead Empty flash at 0x3fa800b0 ends at 0x3fa80500 jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x3fa80500: 0xfcff instead VFS: Mounted root (jffs2 filesystem) on device 31:3. Freeing init memory: 136K Kernel panic - not syncing: No init found. Try passing init= option to kernel. Any help would be appericated!
Boot fails using Openembedded rootfs
This has popped up before, have even had the error myself. You did search <Magic bitmask 0x1985 not found at>? For example: http://forums.freescale.com/t5/Other-Microcontrollers/JFFS2-complaining-...
I have checked the datasheet of the flash (Samsung K9XXG08UXA), and it says: Block Erase : (128K + 4K)Byte So I think I have specified it well with the -e 128KiB option.
Well I have recompiled the kernel using this patch: http://billforums.station51.net/viewtopic.php?f=3&t=167 Now the JFFS2 errors are gone, but the init still not found: NET: Registered protocol family 17 s3c2410-rtc s3c2410-rtc: hctosys: invalid date/time s3c-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). s3c-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). mmc0: new SD card at address 45ed mmcblk0: mmc0:45ed SD02G 1.91 GiB mmcblk0: p1 VFS: Mounted root (jffs2 filesystem) on device 31:3. Freeing init memory: 136K Kernel panic - not syncing: No init found. Try passing init= option to kernel. In the uboot's env there is an bootargs_init=init=/sbin/init The openembedded also generated a tar.gz from the root filesystem, but I cannot found the init in the sbin directory. I have ran bitbake console-image -c clean; bitbake console-image, but the init does not appeared in the sbin directory
I'd suggest posting on: http://groups.google.com/group/mini2440 as Bill seems to reply there sometimes. His own site is getting lots of spam. Good luck
