i have got a new mini2440 but i have some serious memory problem so the arm board is not booting so i try to follow steps given in the manual which says connect the usb and after opening the dnw window and when i start downloading vivi then it says memory full so how do i get through this senario ?
mini2440
yeah i get options like this ##### FriendlyARM BIOS 2.0 for 2440 ##### [x] format NAND FLASH for Linux [v] Download vivi [k] Download linux kernel [y] Download root_yaffs image [a] Absolute User Application [n] Download Nboot for WinCE [l] Download WinCE boot-logo [w] Download WinCE NK.bin [d] Download & Run [z] Download zImage into RAM [g] Boot linux from RAM [f] Format the nand flash [b] Boot the system [s] Set the boot parameters [u] Backup NAND Flash to HOST through USB(upload) [r] Restore NAND Flash from HOST through USB [q] Goto shell of vivi [i] Version: 1026-2K
hi so then there is no problem. You could flash everything back to nand flash. try to search in forum or wiki how to do it ;). good luck, marek
no i have used the same zImage actually i have formatednandFLASH for Linux and downloaded the zimage ...then qt ....asinthemanual it said to rstart the board but when i do that i see different colors on the lcd screen
