Hi everyone, I just received a Mini6410, and with Linux pre-loaded itīs working perfect. My problem cames when i try to install winCE6, when I try to access to the BIOS (S2 in NOR), I follow the procedure with the DNW and it can not access to the supervivi (I donīt see anything in the DNW terminal). I know that the serial cable itīs working fine because when I turn on the mini6410 with the S2 in NAND position the terminal shows me all the status info from the mini6410. Itīs like the the supervivi itīs not pre-loaded? I donīt have any J-TAG to paralel adaptor, itīs possible to load the windows CE from the SD?? Please, help Gurchur
