Hi to all, I have just configured a MINI2440 with an A70 touch screen following the guidelines in mini2440_UM(090415).pdf. In HyperTerminal I can start WinCE using the [b] menu item in Vivi. The problem is that when I disconnect from HyperTerminal, unplug the serial and USB cables, and turn the MINI2440 off, WinCE will not restart automatically when I turn the MINI2440 on. I have to re-connect with HyperTerminal and use the [b] menu item to start WinCE again. I cannot figure out what did I miss in the installation. Any help would be apperciated. Thank you in advance for your replies. Antonio
WinCE doesn't boot
Sounds like you need to move the switch to NAND, not NOR (the other switch that looks like the power switch).
Other possibilities: If you're running CE6, make sure you flash your NOR (with JTAG) to the vivi in the CE6 BSP package. Make sure you flash the NAND with the new vivi too, before flashing the new CE image. That's all I can think of
Hi Spinbot, and thank you for you replies. Infact, if the switch is in NOR position, I can start WinCE 5.0 from HyperTerminal. The problem is that I cannot figure out how to flash the NAND with the vivi. Should I use HyperTerminal or H-JTAG? Is there any guide (help document) for flashing NAND? Thank you again Antonio
Hello Antonio, I also have that mini2440 with A70 touch screen. The screen remains blank. All I see are grid lines. Nothing else! How did you put the J2? 3.3 V or 5.0 V
Hi Killerwatt, the supervivi was already installed on the NOR memory. So I simply followed the guidelines in mini2440_UM(090415).pdf contained in the included CD. So I suggest you to do the same. You shouldn't have problems following the guide because it's quite simple. The problem that I can't solve now is flashing the vivi on tha NAND memory to let th MINI boot directly with WinCE. Antonio
Hello Antonio, I have a mini2440 and an 8-inch screen and have the same problem as you, I think. When I boot the system does not see anything on the screen but I find that if you have installed ActiveSync on the PC, the system synchronizes. So, can it be a problem in the display drivers?. I'm investigating, but findeth a solution, I'd appreciate an answer. Thank you.
Hi Jose Enriqe, if ActiveSynch starts after turning the MINI on, it means that WinCE is detected on the board. Did you use the right image file? I mean, if you have an A70 display, for example, you shold use the files NK_A70.nb0 and NK_A70.bin (or NK_A70_English.nb0 and NK_A70_English.bin for the english version). The NK_A70.nb0 and NK_A70.bin files (and the ones for other types of display) are on the included CD-ROM. I hope this help. Antonio
Hi Antonio, try this. (set S2 to NOR) 1.) press[f] Format the nand flash 2.) press[v] Download vivi (supervivi-128M) 3.) press[n] Download Nboot for WinCE (nboot_A70.bin) 4.) press[l] Download WinCE boot-logo (bootlogo.bmp) 5.) press[w] Download WinCE NK.bin (NK_A70.bin) Switch to NAN and start again.
Look at the readme.txt that comes with WinCE 5 images: I tried yesterday and works: -------------------- How to install: ============= 1. Switch S2 to NOR FLASH, power on the board and enter BIOS 2. Select "n" to download nboot_A70.bin or nboot_N35.bin 3. Select "l" to download bootlogo.bmp 4. Select "w" to download nk_A70.bin or nk.N35.bin 5. Switch S2 to NAND FLASH, power cycle the board Note: 1. You can select "v" to download supervivi image into nand flash in step 2, supervivi does not support progress bar and power on logo. ------------------------- Now my remarks(details - paragraph are numbered as above): 1. Connect the serial cable to the computer and the board, start the Hyperterminal and either open already made connection that worked with mini2440 or make a new one. Then switch to NOR, power the mini2440 (or click reset button if mini is already on). Now on the hyperterminal screen should appears Supervivi boot menu ... 2. If you cant access the supervivi bootmenu - post a message with details what appears on the screen, else if everything is Ok with point 1, go to step 2 (or Note 1) which means you have 3 choices: a) use existing supevivi on the NAND if it is the new supervivi_64M or supervivi_128M and skip point 2 from above b) download the new supervivi_64M or supervivi_128M on the NAND flash with option "v" from the boot menu and DNW tool c) download nboot with option "n" from the boot menu and DNW(but you dont need and supervivi and nboot - anyway both cant coexist in the flash as they share the same segment. Difference is that nboot will give you one extra bootlogo image with progress bar when loading, while with supervivi you'll have only a static image. 3,4 - as per readme (only for 4 you have to use the new DNW tool v 0.5L) Remark: Look at the messages in the Hyperterminal(scroll back if necessary) - if you have some kind a problem - most probably there will be a message there and you could guess where the problem comes from - I had the old vivi installed and cant load neither new supervivi on the NAND nor nboot. After the second attempt I went back in the history and saw that existing vivi bootloader gave me a message that the file I'm trying to flash is too big :( so even if the message don't give you exacly what is the problem you still have enough material for startup to trace where and how to solve it.
Hi Killerwatt and SantaC. I knew that the thing I was missing was very simple (but I couldn't figure out what it was). Infact, after reading your suggestions I reflashed the device and did the fundamental thing I didn't do so far: turning the switch in NAND position after downloading the NK_A70.bin. Now it works perfectly. Thanks to all of you for you precious suggestions. Antonio
Actually i had the same problem, tried the above help not working So I tried as follows 1. Switch S2 to NOR FLASH, power on the board and enter BIOS 2. Select "n" to download nboot_N35.bin 3. Select "i" to download nk.N35.nb0 4. Switch S2 to NAND FLASH, power cycle the board working fine but the option Select "l" to download bootlogo.bmp is not working, Can you tell me how to change the ENGLISH language
