Hi everybody, I'm using the micro2440 with a custom board, which have a micrel KSZ8842 MAC/PHY chip instead of the original DM9000. The memory mapping is the same (I use memory bank 4), and everything works fine if I boot the linux kernel from supervivi. I programmed uboot on the nand flash, and if I boot the linux kernel from uboot, the chip is not recognized. I don't know if I am clear enough, but what I mean is that the behaviour of the kernel is different if I boot from one bootloader or the other. Does anybody have an idea about what is the cause of that problem? Regards, François
Memory problem with Uboot
I'll take a guess and say the u-boot source was generated with the DM9000 as the ethernet component (maybe there is some register setting inconsistancy. Unfortunately, If this is the case then you will need to download the u-boot source, modify it where required, compile, and install. Otherwise, I don't recall any other issue with such a problem. Cheers.
Thanks for your answer. I've already downloaded the uboot source and spent a long time to compare the registers when I boot from vivi and from uboot. I tried with the GPIO regs, clock (CLKCON...), memory (BWSCON, BANKCON4), and even if I found a few differences, changing these values didn't solve my problem. I anybody have an idea about the registers that might be involved, that would help me a lot! Cheers. François
Hi, now sure about that but kernel make self net initialization and not sure if there should be some u-boot dependency. Would be good to ask on u-boot forums on mailing lists to get proper answer ;) marek
Hi, You're right marek, kernel make self net init, but my problem was a little bit different : I removed the dm9000 driver and successfully ported the KSZ8842 driver, so I've a kernel with full working network. The problem is that when I run my "zImage" kernel with supervivi, everything works fine, but when I load the "uImage" conversion of the same kernel, the chip is not detected. But I finally found the trick : The problem is in the uboot mmu init : I found on the net the vivi code for s3c2440, and I noticed several differences. So I changed the mmu init in "lowlevel_foo.S", and everything works now! I don't know if I can call it a "bug" in uboot, but in my opinion, people would expect kernel to work the same way, no matter what bootloader is used. François
Hi Marek,
I'm using the stable version ("mini2440-dev-stable") found here :
http://repo.or.cz/w/u-boot-openmoko/mini2440.git .
cheers.
François
I'm using same but have dm9000 and have no such a troubles. Are you sure problem is in u-boot? Could you please post your changes. thanks, marek
I noticed too that the problem doesn't happen with the DM9000 (I also have
a micro2440 SDK), but the difference is that the KSZ8842 uses 16 bits
addressing (LADDR[0..15] are connected to the chip).
I'm 100% sure that this issue is related to uboot, I tried it several
times, and my little changes to the mmu init code made everything work
so...
Here are the changes I applied, I hope this will be helpful for people who
have a micro2440 and want to use memory bank 4 with other chips than a
DM9000...
In the file "lowlevel_foo.S" (under board/mini2440/ directory) :
/*(no changes before "cpu_init_crit")*/
cpu_init_crit:
* flush v4 I/D caches
mov r0, #0
mcr p15, 0, r0, c7, c7, 0 /* flush v3/v4 cache */
mcr p15, 0, r0, c7, c10, 4 /* drain write buffer on v4 */
mcr p15, 0, r0, c8, c7, 0 /* flush v4 TLB */
/* Load page table pointer */
mov r4, #0
mcr p15, 0, r4, c2, c0, 0 /* load page table pointer */
/* Write domain id (cp15_r3) */
mvn r0, #0 /* Domains 0, 1 = client */
mcr p15, 0, r0, c3, c0, 0 /* load domain access register */
* disable MMU stuff and caches
mrc p15, 0, r0, c1, c0, 0
bic r0, r0, #0x3000 @ clear bits 13, 9:8 (--V- --RS)
bic r0, r0, #0x0300 @ clear bits 7, 2:0 (B--- -CAM)
bic r0, r0, #0x0087
orr r0, r0, #0x00000002 @ set bit 2 (A) Align
orr r0, r0, #0x00001000 @ set bit 12 (I) I-Cache
orr r0, r0, #0x1000
mcr p15, 0, r0, c1, c0, 0
* before relocating, we have to setup RAM timing
* because memory timing is board-dependend, you will
* find a lowlevel_init.S in your board directory.
mov ip, lr
bl lowlevel_init
mov lr, ip
mov pc, lr
cheers,
François
Hi, I also wants to use same configuration means, micro2440 with KSZ8842. Please guide me for KSZ8842 porting in uboot & linux kernel. Thanks in advance.
