Hi, I've made a toolchain from buildroot-2010-11 with same options as toolchain available from friendlyArm. I've also compiled linux ( linux-2.6.32.2-mini2440-20100921.tar.gz ) with this new toolchain and using rootfs ( from rootfs_qtopia_qt4-20100816.tar.gz ), all seems ok. If anyone wants to try it, I've put my buildroot config at http://www.murlock.org/mini2440/buildroot-2010-11.config With friendlyARM $ /opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-gcc -v Using built-in specs. Target: arm-none-linux-gnueabi Configured with: /opt/FriendlyARM/mini2440/build-toolschain/working/src/gcc-4.4.3/configure --build=i386-build_redhat-linux-gnu --host=i386-build_redhat-linux-gnu --target=arm-none-linux-gnueabi --prefix=/opt/FriendlyARM/toolschain/4.4.3 --with-sysroot=/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi//sys-roo t --enable-languages=c,c++ --disable-multilib --with-arch=armv4t --with-cpu=arm920t --with-tune=arm920t --with-float=soft --with-pkgversion=ctng-1.6.1 --disable-sjlj-exceptions --enable-__cxa_atexit --with-gmp=/opt/FriendlyARM/toolschain/4.4.3 --with-mpfr=/opt/FriendlyARM/toolschain/4.4.3 --with-ppl=/opt/FriendlyARM/toolschain/4.4.3 --with-cloog=/opt/FriendlyARM/toolschain/4.4.3 --with-mpc=/opt/FriendlyARM/toolschain/4.4.3 --with-local-prefix=/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi//sy s-root --disable-nls --enable-threads=posix --enable-symvers=gnu --enable-c99 --enable-long-long --enable-target-optspace Thread model: posix gcc version 4.4.3 (ctng-1.6.1) With buildroot toolchain : $ ./output/staging/usr/bin/arm-linux-gcc -v Using built-in specs. Target: arm-unknown-linux-uclibcgnueabi Configured with: /home/murlock/prog/mini2440/src/buildroot-2010.11/output/toolchain/gcc-4.4.5/con figure --prefix=/home/murlock/prog/mini2440/src/buildroot-2010.11/output/staging/usr --build=i686-pc-linux-gnu --host=i686-pc-linux-gnu --target=arm-unknown-linux-uclibcgnueabi --enable-languages=c,c++ --with-sysroot=/home/murlock/prog/mini2440/src/buildroot-2010.11/output/staging --with-build-time-tools=/home/murlock/prog/mini2440/src/buildroot-2010.11/output /staging/usr/arm-unknown-linux-uclibcgnueabi/bin --disable-__cxa_atexit --enable-target-optspace --with-gnu-ld --disable-libssp --disable-multilib --disable-tls --enable-shared --with-gmp=/home/murlock/prog/mini2440/src/buildroot-2010.11/output/toolchain/gm p --with-mpfr=/home/murlock/prog/mini2440/src/buildroot-2010.11/output/toolchain/m pfr --disable-nls --enable-threads --disable-decimal-float --with-float=soft --with-abi=aapcs-linux --with-arch=armv4t --with-tune=arm920t --with-arch=armv4t --with-cpu=arm920t --with-tune=arm920t --with-pkgversion='Buildroot 2010.11' --with-bugurl=http://bugs.buildroot.net/ Thread model: posix gcc version 4.4.5 (Buildroot 2010.11)
