Hello, i'm trying to flash u-boot and angstrom to the mini2440. after following this tutorial http://code.google.com/p/mini2440/wiki/MiniBringup i'm stuck at the part after flashing u-boot for the first time when i reset my mini2440 with the new u-boot nothing happens on the terminal ( i'm using picocom). i compiled angstrom, u-boot, and the kernel following this tutorial http://www.electronics.diycinema.co.uk/embedded/mini2440/bitbaking-the-k... p.s. i wrote the right size of my u-boot.bin in the nand write.e command and saved the env variable after switching off and changing to nand for a reboot. thanks in advance, Riccardo.
problem with uboot
This is what i get when i start u-boot from ram
U-Boot 1.3.2-mini2440 (Jan 17 2011 - 17:12:16)
I2C: ready
DRAM: 64 MB
Flash: 2 MB
NAND: 1024 MiB
*** Warning - bad CRC or NAND, using default environment
USB: S3C2410 USB Deviced
In: serial
Out: serial
Err: serial
MAC: 08:08:11:18:12:27
MINI2440 # printenv
bootargs=root=/dev/mtdblock3 rootfstype=jffs2 console=ttySAC0,115200
bootcmd=
bootdelay=3
baudrate=115200
ethaddr=08:08:11:18:12:27
ipaddr=10.0.0.111
serverip=10.0.0.4
netmask=255.255.255.0
usbtty=cdc_acm
mtdparts=mtdparts=mini2440-nand:256k@0(u-boot),128k(env),5m(kernel),-(root)
mini2440=mini2440=0tb
bootargs_init=init=/sbin/init
root_nfs=/mnt/nfs
ifconfig=ip=dhcp
${mini2440} ${root_mmc}
${mini2440} ${root_nand}
mtdids=nand0=mini2440-nand
partition=nand0,0
mtddevnum=0
mtddevname=u-boot
after a lot of trial and error i got this error when i switch to nand and give the reset message: MINI2440 # reset� U-Boot 1.3.2-mini2440 (Jan 17 2011 - 17:12:16) I2C: ready DRAM: 64 MB Flash: 2 MB NAND: nand_scan(): Cannot allocate oob_buf 0 MiB
