i have read an article about the Mini2440 UARTs TTL level which is(3.3v) "http://www.esky-sh.com/bbs//viewtopic.php?f=6&t=243" my question: is it possible to connect Max485 on (CON1-CON3)
rs485 by using max485
I would look at the datasheet to confirm if the MAX485 will work properly with 3V3 logic levels. I think a better part would be the MAX3485 which works with 3.3V and 5V logic levels. Good luck.
