Hello, I have an mini2440 board with Qtopia 2.2.0 128M+ 2010-01-08 image installed. Id' like to compile tslib for this board. /autogen.sh echo "ac_cv_func_malloc_0_nonnull=yes" > arm-linux.autogen export CC=/usr/local/arm/4.3.2/bin/arm-linux-gcc export CXX=/usr/local/arm/4.3.2/bin/arm-linux-g++ export CONFIG_SITE=arm-linux.autogen ./configure --build=i386-linux --host=arm-linux --target=arm-linux --prefix=$PWD/build make make install there is no any errors during the build process. After copying files to mini2440 board I execute following script export TSLIB_TSDEVICE=/dev/input/event0 export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=/etc/ts.conf export TSLIB_PLUGINDIR=/lib/ts export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_CONSOLEDEVICE=none export QWS_MOUSE_PROTO=tslib:/dev/input/event0 and modify /etc/ts.conf module_raw input module pthres pmin=1 module variance delta=30 module dejitter delta=100 module linear when I try to run any tslib app like ts_calibrate, I have "segmentation fault" error.
mini2440 and tslib
davef, thanks a lot for you answer. I try to use other board with newer Qtopia image and tslib is working now. But the problem is that every tap on touchscreen is go not only to application, but also into Qtopia menu or application. For example, I run ts_calibrate. When I tap crosshair in left upper corner, ts_calibrate is handling my tap and crosshair is moving to the right. But also a background application appears at left corner of screen, at place of crosshair, and this application handling this tap too!
This topic has come up before on this forum. Try search, but can't suggest a keyword for you. Something to do with trying to run a Qt 4.x application while Qt 2.2.0 was also installed. Good luck
