I tried to cross compile python 2.6.5 with buildroot but ended with this error when configuring: checking for %zd printf() format support... configure: error: cannot run test program while cross compiling See `config.log' for more details. I tried python-2.6.5-xcompile.patch (http://randomsplat.com/wp-content/uploads/2010/04/Python-2.6.5-xcompile....) but no luck What is the patch I have to apply to get rid of this error? Thanks
Build Python 2.6.5 with Buildroot fail
Which version of buildroot? Try with latest git HEAD and works fine here. Better will be ask on buildroot mailing list. marek
Thank, marek This is the first line of the buildroot Makefile export BR2_VERSION:=2011.02-git It work OK with the default python version 2.4.5. But when I build HPLIP, it require python 2.6. And I could not compile python 2.6.5 with buildroot
Could you please post your .config file. Will test at home because at work I'm behind proxy which blocks everything except port 80 :D good luck, marek
Hi marek, Below is my buildroot/package/python/python.mk ############################################################# # # python # ############################################################# PYTHON_VERSION=2.6.5 PYTHON_VERSION_MAJOR=2.6 PYTHON_SOURCE:=Python-$(PYTHON_VERSION).tar.bz2 PYTHON_SITE:=http://python.org/ftp/python/$(PYTHON_VERSION) PYTHON_DIR:=$(BUILD_DIR)/Python-$(PYTHON_VERSION) PYTHON_CAT:=$(BZCAT) PYTHON_BINARY:=python PYTHON_TARGET_BINARY:=usr/bin/python$(PYTHON_VERSION_MAJOR) PYTHON_DEPS:= PYTHON_SITE_PACKAGE_DIR=$(TARGET_DIR)/usr/lib/python$(PYTHON_VERSION_MAJOR)/site -packages BR2_PYTHON_DISABLED_MODULES=dbm zipfile ifeq ($(BR2_PACKAGE_PYTHON_READLINE),y) PYTHON_DEPS += readline else BR2_PYTHON_DISABLED_MODULES += readline endif ifeq ($(BR2_PACKAGE_PYTHON_CURSES),y) PYTHON_DEPS += ncurses else BR2_PYTHON_DISABLED_MODULES += _curses _curses_panel endif ifeq ($(BR2_PACKAGE_PYTHON_PYEXPAT),y) PYTHON_DEPS += expat else BR2_PYTHON_DISABLED_MODULES += pyexpat endif ifeq ($(BR2_PACKAGE_PYTHON_GDBM),y) PYTHON_DEPS += gdbm else "package/python/python.mk" [readonly] 212 lines, 6522 characters and below is my .config file # # Automatically generated make config: don't edit # Buildroot version: 2011.02-git-00196-g6b0e9dd-dirty # Tue Jan 11 03:55:27 2011 # BR2_HAVE_DOT_CONFIG=y BR2_arm=y # BR2_armeb is not set # BR2_avr32 is not set # BR2_i386 is not set # BR2_mips is not set # BR2_mipsel is not set # BR2_powerpc is not set # BR2_sh is not set # BR2_sh64 is not set # BR2_sparc is not set # BR2_x86_64 is not set # BR2_xtensa is not set # BR2_generic_arm is not set # BR2_arm7tdmi is not set # BR2_arm610 is not set # BR2_arm710 is not set # BR2_arm720t is not set BR2_arm920t=y # BR2_arm922t is not set # BR2_arm926t is not set # BR2_arm10t is not set # BR2_arm1136jf_s is not set # BR2_arm1176jz_s is not set # BR2_arm1176jzf_s is not set # # cortex-A8/A9 needs gcc >= 4.4.x # # BR2_cortex_a8 is not set # BR2_cortex_a9 is not set # BR2_sa110 is not set # BR2_sa1100 is not set # BR2_xscale is not set # BR2_iwmmxt is not set BR2_ARM_TYPE="ARM920T" BR2_ARM_EABI=y # BR2_ARM_OABI is not set BR2_ARCH="arm" BR2_ENDIAN="LITTLE" BR2_GCC_TARGET_TUNE="arm920t" BR2_GCC_TARGET_ARCH="armv4t" BR2_GCC_TARGET_ABI="aapcs-linux" # # Build options # # # Commands # BR2_WGET="wget --passive-ftp -nd" BR2_SVN="svn" BR2_BZR="bzr" BR2_GIT="git clone" BR2_ZCAT="gzip -d -c" BR2_BZCAT="bzcat" BR2_TAR_OPTIONS="" BR2_DL_DIR="$(TOPDIR)/dl" BR2_STAGING_DIR="$(BASE_DIR)/staging" # # Mirrors and Download locations # BR2_PRIMARY_SITE="" BR2_BACKUP_SITE="http://sources.buildroot.net/" BR2_SOURCEFORGE_MIRROR="easynews" BR2_KERNEL_MIRROR="http://www.kernel.org/pub/" BR2_GNU_MIRROR="http://ftp.gnu.org/pub/gnu" BR2_DEBIAN_MIRROR="http://ftp.debian.org" BR2_JLEVEL=3 # BR2_CCACHE is not set # BR2_DEPRECATED is not set # BR2_ENABLE_DEBUG is not set BR2_STRIP_strip=y # BR2_STRIP_sstrip is not set # BR2_STRIP_none is not set # BR2_OPTIMIZE_0 is not set # BR2_OPTIMIZE_1 is not set BR2_OPTIMIZE_2=y # BR2_OPTIMIZE_3 is not set # BR2_OPTIMIZE_S is not set # BR2_PREFER_STATIC_LIB is not set # BR2_HAVE_DOCUMENTATION is not set # BR2_HAVE_DEVFILES is not set # # Toolchain # BR2_TOOLCHAIN_BUILDROOT=y # BR2_TOOLCHAIN_EXTERNAL is not set # BR2_TOOLCHAIN_CTNG is not set # # Kernel Header Options # # BR2_KERNEL_HEADERS_2_6_34 is not set # BR2_KERNEL_HEADERS_2_6_35 is not set BR2_KERNEL_HEADERS_2_6_36=y # BR2_KERNEL_HEADERS_VERSION is not set # BR2_KERNEL_HEADERS_SNAP is not set BR2_DEFAULT_KERNEL_HEADERS="2.6.36.2" # # uClibc Options # # BR2_UCLIBC_VERSION_0_9_30 is not set BR2_UCLIBC_VERSION_0_9_31=y # BR2_UCLIBC_VERSION_0_9_32 is not set # BR2_UCLIBC_VERSION_SNAPSHOT is not set BR2_UCLIBC_VERSION_STRING="0.9.31" BR2_UCLIBC_CONFIG="toolchain/uClibc/uClibc-0.9.31.config" BR2_PTHREAD_DEBUG=y # BR2_UCLIBC_INSTALL_TEST_SUITE is not set # # Binutils Options # # BR2_BINUTILS_VERSION_2_20 is not set BR2_BINUTILS_VERSION_2_20_1=y BR2_BINUTILS_VERSION="2.20.1" BR2_EXTRA_BINUTILS_CONFIG_OPTIONS="" # # GCC Options # # BR2_GCC_VERSION_4_2_4 is not set # BR2_GCC_VERSION_4_3_X is not set BR2_GCC_VERSION_4_4_X=y # BR2_GCC_VERSION_4_5_X is not set # BR2_GCC_VERSION_SNAP is not set BR2_GCC_SUPPORTS_FINEGRAINEDMTUNE=y BR2_GCC_VERSION="4.4.5" BR2_EXTRA_GCC_CONFIG_OPTIONS="" # BR2_GCC_CROSS_OBJC is not set # BR2_GCC_CROSS_FORTRAN is not set # BR2_INSTALL_OBJC is not set # BR2_INSTALL_FORTRAN is not set BR2_GCC_SHARED_LIBGCC=y # # Gdb Options # # BR2_PACKAGE_GDB is not set # BR2_PACKAGE_GDB_SERVER is not set # BR2_PACKAGE_GDB_HOST is not set BR2_LARGEFILE=y BR2_INET_IPV6=y BR2_INET_RPC=y BR2_USE_WCHAR=y BR2_ENABLE_LOCALE=y BR2_PROGRAM_INVOCATION=y BR2_INSTALL_LIBSTDCPP=y BR2_TOOLCHAIN_HAS_THREADS=y # BR2_ENABLE_LOCALE_PURGE is not set BR2_NEEDS_GETTEXT=y BR2_NEEDS_GETTEXT_IF_LOCALE=y BR2_PREFER_SOFT_FLOAT=y BR2_SOFT_FLOAT=y BR2_TARGET_OPTIMIZATION="-pipe" # # Toolchain Options # BR2_TOOLCHAIN_BUILDROOT_LARGEFILE=y BR2_TOOLCHAIN_BUILDROOT_INET_IPV6=y BR2_TOOLCHAIN_BUILDROOT_INET_RPC=y BR2_TOOLCHAIN_BUILDROOT_WCHAR=y BR2_TOOLCHAIN_BUILDROOT_LOCALE=y BR2_TOOLCHAIN_BUILDROOT_PROGRAM_INVOCATION=y BR2_TOOLCHAIN_BUILDROOT_CXX=y # BR2_TOOLCHAIN_BUILDROOT_USE_SSP is not set # BR2_PTHREADS_NONE is not set # BR2_PTHREADS is not set BR2_PTHREADS_OLD=y # BR2_ELF2FLT is not set BR2_MKLIBS=y # BR2_PACKAGE_SSTRIP_TARGET is not set # BR2_PACKAGE_SSTRIP_HOST is not set BR2_CROSS_TOOLCHAIN_TARGET_UTILS=y # # System configuration # BR2_TARGET_GENERIC_HOSTNAME="buildroot" BR2_TARGET_GENERIC_ISSUE="Welcome to Buildroot" BR2_TARGET_GENERIC_GETTY=y BR2_TARGET_GENERIC_GETTY_PORT="ttySAC0" # BR2_TARGET_GENERIC_GETTY_BAUDRATE_KEEP is not set # BR2_TARGET_GENERIC_GETTY_BAUDRATE_9600 is not set # BR2_TARGET_GENERIC_GETTY_BAUDRATE_19200 is not set # BR2_TARGET_GENERIC_GETTY_BAUDRATE_38400 is not set # BR2_TARGET_GENERIC_GETTY_BAUDRATE_57600 is not set BR2_TARGET_GENERIC_GETTY_BAUDRATE_115200=y BR2_TARGET_GENERIC_GETTY_BAUDRATE="115200" # # Package Selection for the target # BR2_PACKAGE_BUSYBOX=y BR2_BUSYBOX_VERSION_1_16_X=y # BR2_BUSYBOX_VERSION_1_17_X is not set # BR2_BUSYBOX_VERSION_1_18_X is not set # BR2_PACKAGE_BUSYBOX_SNAPSHOT is not set BR2_BUSYBOX_VERSION="1.16.2" BR2_PACKAGE_BUSYBOX_CONFIG="package/busybox/busybox-1.16.x.config" BR2_PACKAGE_BUSYBOX_SHOW_OTHERS=y # BR2_PACKAGE_CUSTOMIZE is not set # # Audio and video libraries and applications # # BR2_PACKAGE_ALSA_LIB is not set # BR2_PACKAGE_AUMIX is not set # BR2_PACKAGE_FLAC is not set # BR2_PACKAGE_FFMPEG is not set # BR2_PACKAGE_GSTREAMER is not set # BR2_PACKAGE_LIBCDAUDIO is not set # BR2_PACKAGE_LIBDVDREAD is not set # BR2_PACKAGE_LIBDVDNAV is not set # BR2_PACKAGE_LIBID3TAG is not set # BR2_PACKAGE_LIBMAD is not set # BR2_PACKAGE_LIBMMS is not set # BR2_PACKAGE_LIBMPD is not set # BR2_PACKAGE_LIBMPEG2 is not set # BR2_PACKAGE_LIBOGG is not set # BR2_PACKAGE_LIBSNDFILE is not set # BR2_PACKAGE_LIBTHEORA is not set # BR2_PACKAGE_LIBVORBIS is not set # BR2_PACKAGE_MADPLAY is not set # BR2_PACKAGE_MPG123 is not set # BR2_PACKAGE_MPLAYER is not set # BR2_PACKAGE_SPEEX is not set # BR2_PACKAGE_SWFDEC is not set # BR2_PACKAGE_FESTIVAL is not set # BR2_PACKAGE_TAGLIB is not set # BR2_PACKAGE_TREMOR is not set # # Compressors and decompressors # BR2_PACKAGE_BZIP2=y # BR2_PACKAGE_GZIP is not set # BR2_PACKAGE_LZOP is not set # BR2_PACKAGE_XZ is not set # # Debugging, profiling and benchmark # # BR2_PACKAGE_DHRYSTONE is not set # BR2_PACKAGE_DMALLOC is not set # BR2_PACKAGE_KEXEC is not set # BR2_PACKAGE_LMBENCH is not set # BR2_PACKAGE_LSOF is not set # BR2_PACKAGE_LTP_TESTSUITE is not set # BR2_PACKAGE_LTRACE is not set # BR2_PACKAGE_MEMSTAT is not set # BR2_PACKAGE_NETPERF is not set # BR2_PACKAGE_OPROFILE is not set # BR2_PACKAGE_STRACE is not set # BR2_PACKAGE_WHETSTONE is not set # # Development tools # # BR2_PACKAGE_AUTOCONF is not set # BR2_PACKAGE_AUTOMAKE is not set # BR2_PACKAGE_BISON is not set # BR2_PACKAGE_BSDIFF is not set # BR2_PACKAGE_CCACHE is not set # BR2_PACKAGE_COREUTILS is not set # BR2_PACKAGE_CVS is not set # BR2_PACKAGE_DIFFUTILS is not set # BR2_PACKAGE_DISTCC is not set # BR2_PACKAGE_FAKEROOT is not set # BR2_PACKAGE_FINDUTILS is not set # BR2_PACKAGE_FLEX is not set # BR2_PACKAGE_GAWK is not set # # native toolchain needs development files in target filesystem # BR2_PACKAGE_GETTEXT=y # BR2_PACKAGE_GETTEXT_STATIC is not set BR2_PACKAGE_LIBINTL=y # BR2_PACKAGE_GMP is not set # BR2_PACKAGE_GPERF is not set # BR2_PACKAGE_GREP is not set BR2_PACKAGE_MAKE=y # BR2_PACKAGE_MPC is not set # BR2_PACKAGE_MPFR is not set # BR2_PACKAGE_LIBTOOL is not set # BR2_PACKAGE_M4 is not set # BR2_PACKAGE_PATCH is not set # BR2_PACKAGE_PKG_CONFIG is not set # BR2_PACKAGE_SED is not set # BR2_PACKAGE_TAR is not set # # Games # # BR2_PACKAGE_GNUCHESS is not set # BR2_PACKAGE_PRBOOM is not set # # Graphic libraries and applications (graphic/text) # # # Graphic applications # # BR2_PACKAGE_RRDTOOL is not set # # graphic libraries # # BR2_PACKAGE_DIRECTFB is not set # BR2_PACKAGE_FBDUMP is not set # BR2_PACKAGE_FBGRAB is not set # BR2_PACKAGE_FBSET is not set # BR2_PACKAGE_FBV is not set # BR2_PACKAGE_IMAGEMAGICK is not set # BR2_PACKAGE_LINUX_FUSION is not set # BR2_PACKAGE_SDL is not set # # oth...stripped-down
# other GUIs # BR2_PACKAGE_QT=y # BR2_PACKAGE_QT_DEBUG is not set # BR2_PACKAGE_QT_DEMOS is not set BR2_PACKAGE_QT_SHARED=y # BR2_PACKAGE_QT_STATIC is not set BR2_PACKAGE_QT_LICENSE_APPROVED=y # BR2_PACKAGE_QT_QT3SUPPORT is not set BR2_PACKAGE_QT_GUI_MODULE=y # # Pixel depths # # # Deselecting each option leads to Qt's default (8,16,32) # # BR2_PACKAGE_QT_PIXEL_DEPTH_1 is not set # BR2_PACKAGE_QT_PIXEL_DEPTH_4 is not set BR2_PACKAGE_QT_PIXEL_DEPTH_8=y # BR2_PACKAGE_QT_PIXEL_DEPTH_12 is not set # BR2_PACKAGE_QT_PIXEL_DEPTH_15 is not set BR2_PACKAGE_QT_PIXEL_DEPTH_16=y # BR2_PACKAGE_QT_PIXEL_DEPTH_18 is not set # BR2_PACKAGE_QT_PIXEL_DEPTH_24 is not set BR2_PACKAGE_QT_PIXEL_DEPTH_32=y # # Fonts # BR2_PACKAGE_QT_FONT_MICRO=y BR2_PACKAGE_QT_FONT_FIXED=y BR2_PACKAGE_QT_FONT_HELVETICA=y # BR2_PACKAGE_QT_FONT_JAPANESE is not set BR2_PACKAGE_QT_FONT_UNIFONT=y BR2_PACKAGE_QT_NOFREETYPE=y # BR2_PACKAGE_QT_QTFREETYPE is not set # BR2_PACKAGE_QT_SYSTEMFREETYPE is not set BR2_PACKAGE_QT_GIF=y BR2_PACKAGE_QT_LIBMNG=y # BR2_PACKAGE_QT_NOJPEG is not set # BR2_PACKAGE_QT_SYSTEMJPEG is not set BR2_PACKAGE_QT_QTJPEG=y BR2_PACKAGE_QT_NOPNG=y # BR2_PACKAGE_QT_SYSTEMPNG is not set # BR2_PACKAGE_QT_QTPNG is not set BR2_PACKAGE_QT_NOTIFF=y # BR2_PACKAGE_QT_SYSTEMTIFF is not set # BR2_PACKAGE_QT_QTTIFF is not set BR2_PACKAGE_QT_QTZLIB=y # BR2_PACKAGE_QT_SYSTEMZLIB is not set BR2_PACKAGE_QT_EMB_PLATFORM="arm" # BR2_PACKAGE_QT_SQL_MODULE is not set # # Graphics drivers # BR2_PACKAGE_QT_GFX_LINUXFB=y # BR2_PACKAGE_QT_GFX_TRANSFORMED is not set # BR2_PACKAGE_QT_GFX_QVFB is not set # BR2_PACKAGE_QT_GFX_VNC is not set # BR2_PACKAGE_QT_GFX_MULTISCREEN is not set # # directfb Qt driver not available (need directfb) # # # Mouse drivers # # BR2_PACKAGE_QT_MOUSE_PC is not set # BR2_PACKAGE_QT_MOUSE_LINUXTP is not set # BR2_PACKAGE_QT_MOUSE_LINUXINPUT is not set # BR2_PACKAGE_QT_MOUSE_TSLIB is not set # BR2_PACKAGE_QT_MOUSE_QVFB is not set # # Keyboard drivers # # BR2_PACKAGE_QT_KEYBOARD_TTY is not set # BR2_PACKAGE_QT_KEYBOARD_LINUXINPUT is not set # BR2_PACKAGE_QT_KEYBOARD_QVFB is not set # # Phonon module needs gstreamer # # BR2_PACKAGE_QT_DBUS is not set BR2_PACKAGE_QT_XML=y # BR2_PACKAGE_QT_XMLPATTERNS is not set # BR2_PACKAGE_QT_MULTIMEDIA is not set # BR2_PACKAGE_QT_SVG is not set BR2_PACKAGE_QT_NETWORK=y # BR2_PACKAGE_QT_WEBKIT is not set # BR2_PACKAGE_QT_JAVASCRIPTCORE is not set # BR2_PACKAGE_QT_STL is not set # BR2_PACKAGE_QT_OPENSSL is not set BR2_PACKAGE_QT_SCRIPT=y # BR2_PACKAGE_QT_SCRIPTTOOLS is not set # BR2_PACKAGE_XORG7 is not set # # X libraries and helper libraries # # BR2_PACKAGE_LIBERATION is not set # # X Window managers # # # X applications # # BR2_PACKAGE_GOB2 is not set # # midori requires C++, WCHAR in toolchain and libgtk2 # # # Hardware handling # BR2_PACKAGE_CDRKIT=y # BR2_PACKAGE_CRAMFS is not set BR2_PACKAGE_DBUS=y BR2_DBUS_EXPAT=y # BR2_DBUS_LIBXML2 is not set # BR2_PACKAGE_DBUS_GLIB is not set # BR2_PACKAGE_DBUS_PYTHON is not set BR2_PACKAGE_DEVMEM2=y BR2_PACKAGE_DMRAID=y BR2_PACKAGE_DOSFSTOOLS=y BR2_PACKAGE_DOSFSTOOLS_MKDOSFS=y BR2_PACKAGE_DOSFSTOOLS_DOSFSCK=y BR2_PACKAGE_DOSFSTOOLS_DOSFSLABEL=y BR2_PACKAGE_E2FSPROGS=y BR2_PACKAGE_E2FSPROGS_UTILS=y BR2_PACKAGE_E2FSPROGS_BADBLOCKS=y BR2_PACKAGE_E2FSPROGS_BLKID=y BR2_PACKAGE_E2FSPROGS_CHATTR=y BR2_PACKAGE_E2FSPROGS_DUMPE2FS=y BR2_PACKAGE_E2FSPROGS_E2FREEFRAG=y BR2_PACKAGE_E2FSPROGS_E2FSCK=y BR2_PACKAGE_E2FSPROGS_E2LABEL=y BR2_PACKAGE_E2FSPROGS_E2UNDO=y BR2_PACKAGE_E2FSPROGS_FILEFRAG=y BR2_PACKAGE_E2FSPROGS_FINDFS=y BR2_PACKAGE_E2FSPROGS_FSCK=y BR2_PACKAGE_E2FSPROGS_LOGSAVE=y BR2_PACKAGE_E2FSPROGS_LSATTR=y BR2_PACKAGE_E2FSPROGS_MKE2FS=y BR2_PACKAGE_E2FSPROGS_MKLOSTFOUND=y BR2_PACKAGE_E2FSPROGS_TUNE2FS=y BR2_PACKAGE_E2FSPROGS_UUIDGEN=y BR2_PACKAGE_E2FSPROGS_UUIDD=y # # e2fsprogs libraries # BR2_PACKAGE_E2FSPROGS_LIBUUID=y BR2_PACKAGE_E2FSPROGS_LIBBLKID=y # BR2_PACKAGE_EEPROG is not set # BR2_PACKAGE_FCONFIG is not set # BR2_PACKAGE_FIS is not set # BR2_PACKAGE_GADGETFS_TEST is not set # BR2_PACKAGE_GENEXT2FS is not set # BR2_PACKAGE_GENROMFS is not set # BR2_PACKAGE_GPSD is not set # BR2_PACKAGE_GVFS is not set # BR2_PACKAGE_HAL is not set # BR2_PACKAGE_HDPARM is not set # BR2_PACKAGE_HWDATA is not set # BR2_PACKAGE_I2C_TOOLS is not set # BR2_PACKAGE_INPUT_TOOLS is not set # BR2_PACKAGE_IOSTAT is not set # BR2_PACKAGE_KBD is not set # BR2_PACKAGE_LM_SENSORS is not set # BR2_PACKAGE_LSUIO is not set BR2_PACKAGE_LVM2=y # BR2_PACKAGE_LVM2_DMSETUP_ONLY is not set # BR2_PACKAGE_MAKEDEVS is not set # BR2_PACKAGE_MDADM is not set # BR2_PACKAGE_MEMTESTER is not set # BR2_PACKAGE_MTD is not set # BR2_PACKAGE_NTFS_3G is not set # BR2_PACKAGE_NTFSPROGS is not set # BR2_PACKAGE_PCIUTILS is not set # BR2_PACKAGE_RNG_TOOLS is not set # BR2_PACKAGE_SETSERIAL is not set # BR2_PACKAGE_SMARTMONTOOLS is not set # BR2_PACKAGE_SQUASHFS is not set BR2_PACKAGE_SYSSTAT=y BR2_PACKAGE_UDEV=y BR2_PACKAGE_UDEV_UTILS=y # # Extra udev tools # BR2_PACKAGE_UDEV_VOLUME_ID=y BR2_PACKAGE_UDEV_SCSI_ID=y BR2_PACKAGE_UDEV_PATH_ID=y BR2_PACKAGE_UDEV_FIRMWARE_SH=y BR2_PACKAGE_USB_MODESWITCH=y BR2_PACKAGE_USBMOUNT=y BR2_PACKAGE_USBUTILS=y BR2_PACKAGE_USBUTILS_ZLIB=y # BR2_PACKAGE_WIPE is not set # BR2_PACKAGE_XFSPROGS is not set # # Interpreter languages and scripting # # BR2_PACKAGE_HASERL is not set # BR2_PACKAGE_LUA is not set # BR2_PACKAGE_MICROPERL is not set # BR2_PACKAGE_PHP is not set BR2_PACKAGE_PYTHON=y # BR2_PACKAGE_PYTHON_DEV is not set BR2_PACKAGE_PYTHON_PY_ONLY=y # BR2_PACKAGE_PYTHON_PYC_ONLY is not set # BR2_PACKAGE_PYTHON_PY_PYC is not set # # The following modules are unusual or require extra libraries # # BR2_PACKAGE_PYTHON_BSDDB is not set BR2_PACKAGE_PYTHON_CODECSCJK=y # BR2_PACKAGE_PYTHON_CURSES is not set # BR2_PACKAGE_PYTHON_PYEXPAT is not set # BR2_PACKAGE_PYTHON_READLINE is not set # BR2_PACKAGE_PYTHON_SSL is not set # BR2_PACKAGE_PYTHON_TKINTER is not set BR2_PACKAGE_PYTHON_UNICODEDATA=y # BR2_PACKAGE_RUBY is not set # BR2_PACKAGE_TCL is not set # # Libraries # # # Compression and decompression # BR2_PACKAGE_LIBARCHIVE=y BR2_PACKAGE_LIBARCHIVE_BSDTAR=y BR2_PACKAGE_LIBARCHIVE_BSDCPIO=y BR2_PACKAGE_LZO=y BR2_PACKAGE_ZLIB=y # # Crypto # # BR2_PACKAGE_BEECRYPT is not set BR2_PACKAGE_LIBGCRYPT=y BR2_PACKAGE_LIBGPG_ERROR=y BR2_PACKAGE_OPENSSL=y BR2_PACKAGE_OPENSSL_BIN=y # BR2_PACKAGE_OPENSSL_ENGINES is not set # # Database # # BR2_PACKAGE_BERKELEYDB is not set # BR2_PACKAGE_MYSQL_CLIENT is not set # BR2_PACKAGE_SQLITE is not set # # Filesystem # # BR2_PACKAGE_GAMIN is not set # BR2_PACKAGE_LIBCONFIG is not set # BR2_PACKAGE_LIBCONFUSE is not set # BR2_PACKAGE_LIBFUSE is not set BR2_PACKAGE_LIBLOCKFILE=y BR2_PACKAGE_LIBSYSFS=y # # Graphics # # BR2_PACKAGE_ATK is not set # BR2_PACKAGE_CAIRO is not set # BR2_PACKAGE_FONTCONFIG is not set # BR2_PACKAGE_FREETYPE is not set BR2_PACKAGE_JPEG=y BR2_PACKAGE_LIBART=y # BR2_PACKAGE_GDK_PIXBUF is not set BR2_PACKAGE_LIBPNG=y # BR2_PACKAGE_LIBSVGTINY is not set # BR2_PACKAGE_LIBUNGIF is not set # BR2_PACKAGE_PANGO is not set # BR2_PACKAGE_PIXMAN is not set # BR2_PACKAGE_TIFF is not set # # webkit requires C++, WCHAR in toolchain and libgtk2 # # # Hardware handling # # BR2_PACKAGE_LIBAIO is not set # BR2_PACKAGE_LIBRAW1394 is not set BR2_PACKAGE_TSLIB=y BR2_PACKAGE_LIBUSB=y BR2_PACKAGE_LIBUSB_COMPAT=y # # Networking # # BR2_PACKAGE_LIBCGI is not set # BR2_PACKAGE_LIBCGICC is not set # BR2_PACKAGE_LIBCURL is not set # BR2_PACKAGE_LIBDNET is not set # BR2_PACKAGE_LIBEXOSIP2 is not set # BR2_PACKAGE_LIBIDN is not set # BR2_PACKAGE_LIBMICROHTTPD is not set # BR2_PACKAGE_NEON is not set # BR2_PACKAGE_LIBNL is not set # BR2_PACKAGE_LIBPCAP is not set # BR2_PACKAGE_LIBOSIP2 is not set # BR2_PACKAGE_LIBRSYNC is not set # BR2_PACKAGE_LIBSOUP is not set # BR2_PACKAGE_LIBUPNP is not set # # Other # # BR2_PACKAGE_ARGP_STANDALONE is not set # BR2_PACKAGE_LIBATOMIC_OPS is not set BR2_PACKAGE_LIBCAP=y # BR2_PACKAGE_LIBDAEMON is not set # BR2_PACKAGE_LIBELF is not set # BR2_PACKAGE_LIBEVENT is not set # BR2_PACKAGE_LIBGLIB2 is not set # BR2_PACKAGE_LIBOIL is not set # # Text and terminal handling # # BR2_PACKAGE_ENCHANT is not set # BR2_PACKAGE_ICU is not set # BR2_PACKAGE_NCURSES is not set # BR2_PACKAGE_NEWT is not set # BR2_PACKAGE_PCRE is not set # BR2_PACKAGE_POPT is not set # BR2_PACKAGE_READLINE is not set # BR2_PACKAGE_SLANG is not set # # XML # BR2_PACKAGE_EXPAT=y # BR2_PACKAGE_EZXML is not set BR2_PACKAGE_LIBXML2=y # BR2_PACKAGE_LIBXSLT is not set # BR2_PACKAGE_XERCES is not set # # Miscellaneous # # BR2_PACKAGE_SHARED_MIME_INFO is not set # # Networking applications # # BR2_PACKAGE_ARGUS is not set # BR2_PACKAGE_AVAHI is not set # BR2_PACKAGE_AXEL is not set # BR2_PACKAGE_BOA is not set # BR2_PACKAGE_BIND is not set # BR2_PACKAGE_BMON is not set # BR2_PACKAGE_BRIDGE is not set # BR2_PACKAGE_CTORRENT is not set BR2_PACKAGE_CUPS=y BR2_PACKAGE_CUPS_PDFTOPS=y BR2_PACKAGE_HPLIP=y # BR2_PACKAGE_DHCP is not set # BR2_PACKAGE_DNSMASQ is not set # BR2_PACKAGE_DROPBEAR is not set BR2_PACKAGE_ETHTOOL=y # BR2_PACKAGE_HOSTAPD is not set # BR2_PACKAGE_IFPLUGD is not set # BR2_PACKAGE_IPERF is not set # BR2_PACKAGE_IPROUTE2 is not set # BR2_PACKAGE_IPSEC_TOOLS is not set # BR2_PACKAGE_IPTABLES is not set # BR2_PACKAGE_IW is not set # BR2_PACKAGE_KISMET is not set # BR2_PACKAGE_XL2TP is not set # BR2_PACKAGE_LIGHTTPD is not set # BR2_PACKAGE_LINKS is not set # BR2_PACKAGE_LRZSZ is not set # BR2_PACKAGE_MII_DIAG is not set # BR2_PACKAGE_MROUTED is not set # BR2_PACKAGE_MUTT is not set # BR2_PACKAGE_NBD is not set # BR2_PACKAGE_NCFTP is not se...stripped-down
# BR2_PACKAGE_NETCAT is not set # BR2_PACKAGE_NETKITBASE is not set # BR2_PACKAGE_NETKITTELNET is not set # BR2_PACKAGE_NETPLUG is not set BR2_PACKAGE_NETSNMP=y # BR2_PACKAGE_NETSTAT_NAT is not set # BR2_PACKAGE_NFS_UTILS is not set # BR2_PACKAGE_NTP is not set # BR2_PACKAGE_NUTTCP is not set # BR2_PACKAGE_OLSR is not set # BR2_PACKAGE_OPENNTPD is not set # BR2_PACKAGE_OPENSSH is not set # BR2_PACKAGE_OPENVPN is not set # BR2_PACKAGE_PORTMAP is not set # BR2_PACKAGE_PPPD is not set # BR2_PACKAGE_RADVD is not set # BR2_PACKAGE_PPTP_LINUX is not set # BR2_PACKAGE_PROFTPD is not set # BR2_PACKAGE_QUAGGA is not set # BR2_PACKAGE_RSH_REDONE is not set # BR2_PACKAGE_RSYNC is not set # BR2_PACKAGE_SAMBA is not set # BR2_PACKAGE_SER2NET is not set # BR2_PACKAGE_SOCAT is not set # BR2_PACKAGE_SPAWN_FCGI is not set # BR2_PACKAGE_SQUID is not set # BR2_PACKAGE_TCPDUMP is not set # BR2_PACKAGE_DHCPDUMP is not set # BR2_PACKAGE_TCPREPLAY is not set # BR2_PACKAGE_TFTPD is not set # BR2_PACKAGE_THTTPD is not set # BR2_PACKAGE_TINYHTTPD is not set # BR2_PACKAGE_TN5250 is not set # BR2_PACKAGE_TTCP is not set # BR2_PACKAGE_UDPCAST is not set # BR2_PACKAGE_VPNC is not set # BR2_PACKAGE_VSFTPD is not set # BR2_PACKAGE_VTUN is not set # BR2_PACKAGE_WEBIF is not set # BR2_PACKAGE_WGET is not set # BR2_PACKAGE_WIRELESS_TOOLS is not set # BR2_PACKAGE_WPA_SUPPLICANT is not set # # Package managers # # BR2_PACKAGE_IPKG is not set # # rpm requires libneon with SSL, XML and ZLIB support # # # Shell and utilities # # BR2_PACKAGE_AT is not set # BR2_PACKAGE_BASH is not set # BR2_PACKAGE_DASH is not set # BR2_PACKAGE_DIALOG is not set # BR2_PACKAGE_FILE is not set BR2_PACKAGE_LOCKFILE_PROGS=y # BR2_PACKAGE_LOGROTATE is not set # BR2_PACKAGE_SCREEN is not set # BR2_PACKAGE_SUDO is not set # BR2_PACKAGE_WHICH is not set # # System tools # # BR2_PACKAGE_BOOTUTILS is not set # BR2_PACKAGE_MODULE_INIT_TOOLS is not set # BR2_PACKAGE_PROCPS is not set # BR2_PACKAGE_PSMISC is not set # BR2_PACKAGE_SYSKLOGD is not set # BR2_PACKAGE_SYSVINIT is not set # BR2_PACKAGE_UTIL-LINUX is not set # # Text editors and viewers # # BR2_PACKAGE_ED is not set # BR2_PACKAGE_LESS is not set # BR2_PACKAGE_NANO is not set # BR2_PACKAGE_UEMACS is not set # BR2_PACKAGE_VIM is not set # # Target filesystem options # BR2_ROOTFS_POST_BUILD_SCRIPT="" BR2_ROOTFS_DEVICE_TABLE="target/generic/device_table.txt" BR2_ROOTFS_SKELETON_DEFAULT=y # BR2_ROOTFS_SKELETON_CUSTOM is not set # BR2_TARGET_ROOTFS_CRAMFS is not set # BR2_TARGET_ROOTFS_CLOOP is not set BR2_TARGET_ROOTFS_EXT2=y BR2_TARGET_ROOTFS_EXT2_BLOCKS=0 BR2_TARGET_ROOTFS_EXT2_INODES=0 BR2_TARGET_ROOTFS_EXT2_RESBLKS=0 BR2_TARGET_ROOTFS_EXT2_SQUASH=y BR2_TARGET_ROOTFS_EXT2_NONE=y # BR2_TARGET_ROOTFS_EXT2_GZIP is not set # BR2_TARGET_ROOTFS_EXT2_BZIP2 is not set # BR2_TARGET_ROOTFS_EXT2_LZMA is not set BR2_TARGET_ROOTFS_JFFS2=y # BR2_TARGET_ROOTFS_JFFS2_DATAFLASH_1056 is not set # BR2_TARGET_ROOTFS_JFFS2_DATAFLASH_528 is not set # BR2_TARGET_ROOTFS_JFFS2_NANDFLASH_512_16K is not set BR2_TARGET_ROOTFS_JFFS2_NANDFLASH_2K_128K=y # BR2_TARGET_ROOTFS_JFFS2_FLASH_128 is not set # BR2_TARGET_ROOTFS_JFFS2_FLASH_64 is not set # BR2_TARGET_ROOTFS_JFFS2_CUSTOM is not set BR2_TARGET_ROOTFS_JFFS2_PAGESIZE=0x800 BR2_TARGET_ROOTFS_JFFS2_EBSIZE=0x20000 BR2_TARGET_ROOTFS_JFFS2_NOCLEANMARKER=y # BR2_JFFS2_TARGET_SREC is not set # BR2_TARGET_ROOTFS_JFFS2_PAD is not set BR2_TARGET_ROOTFS_JFFS2_LE=y # BR2_TARGET_ROOTFS_JFFS2_BE is not set # BR2_TARGET_ROOTFS_JFFS2_SUMMARY is not set # BR2_TARGET_ROOTFS_UBIFS is not set # BR2_TARGET_ROOTFS_SQUASHFS is not set BR2_TARGET_ROOTFS_TAR=y BR2_TARGET_ROOTFS_TAR_NONE=y # BR2_TARGET_ROOTFS_TAR_GZIP is not set # BR2_TARGET_ROOTFS_TAR_BZIP2 is not set # BR2_TARGET_ROOTFS_TAR_LZMA is not set BR2_TARGET_ROOTFS_TAR_OPTIONS="" # BR2_TARGET_ROOTFS_CPIO is not set # BR2_TARGET_ROOTFS_INITRAMFS is not set # BR2_TARGET_ROOTFS_ROMFS is not set # # Bootloaders # # BR2_TARGET_BAREBOX is not set BR2_TARGET_UBOOT=y BR2_TARGET_UBOOT_BOARDNAME="mini2440" # BR2_TARGET_UBOOT_2010_12 is not set # BR2_TARGET_UBOOT_2010_09 is not set # BR2_TARGET_UBOOT_2010_06 is not set # BR2_TARGET_UBOOT_2010_03 is not set # BR2_TARGET_UBOOT_2009_11 is not set # BR2_TARGET_UBOOT_2009_08 is not set BR2_TARGET_UBOOT_CUSTOM_TARBALL=y BR2_TARGET_UBOOT_CUSTOM_TARBALL_LOCATION="http://repo.or.cz/w/u-boot-openmoko/mini2440.git/snapshot/dev-mini2440-s...; BR2_TARGET_UBOOT_VERSION="custom" BR2_TARGET_UBOOT_CUSTOM_PATCH_DIR="" BR2_TARGET_UBOOT_FORMAT_BIN=y # BR2_TARGET_UBOOT_FORMAT_KWB is not set # BR2_TARGET_UBOOT_TOOL_MKIMAGE is not set # BR2_TARGET_UBOOT_TOOL_ENV is not set # BR2_TARGET_UBOOT_NETWORK is not set # BR2_TARGET_AT91BOOTSTRAP is not set # BR2_TARGET_DATAFLASHBOOT is not set # # Kernel # BR2_LINUX_KERNEL=y # BR2_LINUX_KERNEL_2_6_36 is not set # BR2_LINUX_KERNEL_SAME_AS_HEADERS is not set # BR2_LINUX_KERNEL_CUSTOM_VERSION is not set BR2_LINUX_KERNEL_CUSTOM_TARBALL=y BR2_LINUX_KERNEL_CUSTOM_TARBALL_LOCATION="/home/bao/work/linux-2.6.32.2-min i2440-20100921.tar.gz" BR2_LINUX_KERNEL_VERSION="custom" BR2_LINUX_KERNEL_PATCH="" # BR2_LINUX_KERNEL_USE_DEFCONFIG is not set BR2_LINUX_KERNEL_USE_CUSTOM_CONFIG=y BR2_LINUX_KERNEL_CUSTOM_CONFIG_FILE="./configs/config_mini2440_a70" BR2_LINUX_KERNEL_UIMAGE=y # BR2_LINUX_KERNEL_ZIMAGE is not set
