Hi !! I was playing with BSP following the instructions here: http://www.domodom.fr/spip/Generer-une-image-Windows-CE-pour.html?lang=en (Thanks to domodom !! Great job !!) I follow the instructions and I get the error I've attached here... Pleas, do you have any idea...has someone find this problem?? Thanks in advance...
BSP and Visual Studio
Hello Ivan, My tutoriel is not enough clear, i will precise it, i think you only installed Platform Builder CE 6 without all the revisions (R2 & R3). Can you confirm it ? Best regards Domodom
Hi domodom !! Thanks for your quick reply. It suppose I have installed everything. I didn't find any error. Also I create a new virtual machine and try to install Visual studio 2005 using microsoft site, but the img file is corrupt. So I got other version of VS2005 and follow the next steps: - Try to install SP1: It crashed telling that I don't have VS2005 installed :S - Install CE 6.0: It installed good - Install R2 & R3: It crashed becasue it said I don't have VS2005 installed, neither SP1. After this list of errors I try to open mini2440.sln file from your site and It worked !!. I click on sysgen and start to compile giving me these errors: BUILD: [Thrd:Sequence:Type ] Message BUILD: [01:0000000461:ERRORE] C:\WINCE600\PLATFORM\Mini2440\SRC\DRIVERS\SDHC\SDHCBASE\.\sdiocontrollerbase.cpp (1211) : error C2065: 'ResponseR7' : undeclared identifier BUILD: [01:0000000462:ERRORE] C:\WINCE600\PLATFORM\Mini2440\SRC\DRIVERS\SDHC\SDHCBASE\.\sdiocontrollerbase.cpp (1211) : error C2051: case expression not constant BUILD: [01:0000000463:ERRORE] C:\WINCE600\PLATFORM\Mini2440\SRC\DRIVERS\SDHC\SDHCBASE\.\sdiocontrollerbase.cpp (1312) : error C2051: case expression not constant Thanks best Regards !
