Hi, it's the first time I have this problem When I program my Mini2440 (7") for WinCE by DNW I haven't any error message... and the WinCe boot well from nor memory (at the end of programming sequence) but when I turn off power and then switch to nand I get "Unknown NAND type" on DNW display and the WinCE doesn't boot. I've programmed with the same files (supervivi, nboot and wince image) other Mini2440 board... so... is possible that the nand is broken? please help
Unknown NAND type
Hi Stranet, That is happening to me too! It only boots from the bios.. have trying to work it an I cant
It happend to me when i updated the bootloader on the SD, and not the kernel. try using a superboot.bin that matches the kernel image remco
I get the same message and can only run in nor. Also when I get it running in nor my touch screen doesn't put the cursor where my finger is... do I need to calibrate it?
Got the touch screen calibration done using usb mouse. but still getting unknown NAND type message when switched to NAND. I've tried all the vivi offered. PS I am a beginner at this, so I could be missing something simple.
