I have downloaded the latest Mini6410-WinCE6-Suite-1046 and made the changes in configuration file: SMDK6410.bat I can`t get the touch interface TOUCHCOM-1034 working with WinCE. It is working properly with Linux and Android without making any changes in config files. Please help me to choose right parameters regarding set BSP_NOTOUCH= set BSP_NOTOUCH_ADC= set BSP_NOTOUCHCOM=1 set BSP_NOTOUCH_1WIRE= Or maybe I miss something. Thank you
6410 - touchcom
If i'm not mistaken then you have DISABLED the touchcom driver. bsp_NOtouchcom=1 means "it is true that there is no touchcom" maybe try: set BSP_NOTOUCH=1 set BSP_NOTOUCH_ADC=1 set BSP_NOTOUCHCOM= set BSP_NOTOUCH_1WIRE=1 Thanks, Errol
Thanks for help, I got it working, but the touch screen is not accurate. Pointer is dispayed about 2cm (1 inch) lower than I touch, and there is no calibration "Stylus" in "Control panel". Probably because I am using Touchcom. Any ideas? Thank you
