Hi all, I created new linux system for the micro2440 with buildroot. I can boot the system from NAND flash. From uboot, I can load the uImage from SDCARD by ext2load command. The problem is when the linux kernel is running, I can not see the SDCARD in the /dev/ folder when I plug it in. Below is the output of the console when I plug in my SDCARD. mmc0: new SD card at address 1235 mmcblk0: mmc0:1235 APPSD 1.91 GiB mmcblk0: p1 # ls /dev/mm* ls: /dev/mm*: No such file or directory # I think I am missing some driver for the MMC/SD but I can not figure it out. How can I configure the kernel in order to make the SDCARD work with the kernel? Thank you very much
SDCARD problem
Think your key areas to search or <mdev> <udev> and <hotplug>. Which kernel are you using? Any changes to it?
Thank davef, I am using the linux-2.6.32.2-mini2440-20100921.tar.gz tar ball to build the kernel. The source came with the CD when I buy the board. I follow all the steps in the manual when configuring the linux kernel (make linux26-menuconfig) With the pre-installed linux came with the board, everything is OK. So I think it is not the hardware issue.
I see you have an even later kernel than on the downloads page. Or it is specific for your board. Sorry, can't really suggest anything more. Unfortunately, the DVD kernel images (for the mini2440) do not come with its companion configuration file (for the touchscreen). Likewise, for you? If they were included than you could do a <diff>. Good luck
I put back in the 2.6.32.2 I compiled and both the sdcard and udisk automount, on the mini2440. So, it appears that the configuration files they include in the source are the ones they use to generate the images on the DVD. You'll need some help from someone who has actually used the micro2440. BFN, Daver
Thank you very much, daver By the way, what is the version of the linux you compiled, 2009 or 2010? I will try to use this source on my micro 2440 and see if something happen :D
I disabled the "Hardware support for SDIO IRQ" in the MMC/SD Driver option. It get me to the following error: Waiting for root device /dev/mmcblk0p3... s3c-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). s3c-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). mmc0: new SD card at address 1235 mmcblk0: mmc0:1235 APPSD 1.91 GiB mmcblk0: p1 p2 p3 JBD: Clearing recovery information on journal usb 1-1: new full speed USB device using s3c2410-ohci and address 2 mmcblk0: error -84 transferring data, sector 2486376, nr 8, card status 0xd00 end_request: I/O error, dev mmcblk0, sector 2486376 Buffer I/O error on device mmcblk0p3, logical block 131581 lost page write due to I/O error on mmcblk0p3 kjournald starting. Commit interval 5 seconds EXT3-fs warning (device mmcblk0p3): ext3_clear_journal_err: Filesystem error recorded from previous mount: IO failure EXT3-fs warning (device mmcblk0p3): ext3_clear_journal_err: Marking fs in need of filesystem check. mmcblk0: error -84 transferring data, sector 1433728, nr 8, card status 0xd00 usb 1-1: New USB device found, idVendor=058f, idProduct=9254 usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 usb 1-1: Product: Generic USB Hub usb 1-1: Manufacturer: ALCOR usb 1-1: configuration #1 chosen from 1 choice hub 1-1:1.0: USB hub found hub 1-1:1.0: 4 ports detected end_request: I/O error, dev mmcblk0, sector 1433728 Buffer I/O error on device mmcblk0p3, logical block 0 lost page write due to I/O error on mmcblk0p3 EXT3-fs warning: mounting fs with errors, running e2fsck is recommended ------------[ cut here ]------------ WARNING: at fs/buffer.c:1159 mark_buffer_dirty+0xcc/0xe8() Backtrace: [<c00238dc>] (dump_backtrace+0x0/0x10c) from [<c02ca238>] (dump_stack+0x18/0x1c) r7:c0340cdc r6:00000487 r5:c00a8170 r4:00000000 [<c02ca220>] (dump_stack+0x0/0x1c) from [<c0031208>] (warn_slowpath_common+0x48/0x60) [<c00311c0>] (warn_slowpath_common+0x0/0x60) from [<c0031238>] (warn_slowpath_null+0x18/0x1c) r7:c340a240 r6:c03d0400 r5:c03c1fb0 r4:c3407000 [<c0031220>] (warn_slowpath_null+0x0/0x1c) from [<c00a8170>] (mark_buffer_dirty+0xcc/0xe8) [<c00a80a4>] (mark_buffer_dirty+0x0/0xe8) from [<c00e0fb0>] (T.498+0x54/0x6c) r5:c3407000 r4:c39eca00 [<c00e0f5c>] (T.498+0x0/0x6c) from [<c00e1490>] (ext3_setup_super+0xec/0x210) r7:c340a240 r6:c38e9200 r5:00000000 r4:c39eca00 [<c00e13a4>] (ext3_setup_super+0x0/0x210) from [<c00e2668>] (ext3_fill_super+0xd0c/0x16e4) r7:c340a240 r6:c03d0400 r5:c39eca00 r4:c38e9200 [<c00e195c>] (ext3_fill_super+0x0/0x16e4) from [<c0088124>] (get_sb_bdev+0x140/0x178) [<c0087fe4>] (get_sb_bdev+0x0/0x178) from [<c00dfd98>] (ext3_get_sb+0x24/0x30) [<c00dfd74>] (ext3_get_sb+0x0/0x30) from [<c0087098>] (vfs_kern_mount+0x58/0xe8) [<c0087040>] (vfs_kern_mount+0x0/0xe8) from [<c0087184>] (do_kern_mount+0x3c/0xe4) r8:00008000 r7:c38e81a0 r6:00000000 r5:c38e8180 r4:c038444c [<c0087148>] (do_kern_mount+0x0/0xe4) from [<c009d6b4>] (do_mount+0x158/0x6e4) r9:00000000 r8:c3823ee0 r7:c38e8180 r6:c38e81a0 r5:00000020 r4:00000000 [<c009d55c>] (do_mount+0x0/0x6e4) from [<c009dccc>] (sys_mount+0x8c/0xcc) [<c009dc40>] (sys_mount+0x0/0xcc) from [<c0008c88>] (mount_block_root+0x104/0x2bc) r7:00008000 r6:c001c808 r5:c3812000 r4:c3812000 [<c0008b84>] (mount_block_root+0x0/0x2bc) from [<c0008e94>] (mount_root+0x54/0x6c) [<c0008e40>] (mount_root+0x0/0x6c) from [<c0008fd4>] (prepare_namespace+0x128/0x180) r5:c001c81d r4:c039d640 [<c0008eac>] (prepare_namespace+0x0/0x180) from [<c00084b0>] (kernel_init+0xe0/0x114) r5:c001beec r4:c039d400 [<c00083d0>] (kernel_init+0x0/0x114) from [<c00342f0>] (do_exit+0x0/0x5cc) r5:00000000 r4:00000000 ---[ end trace 35cab5e68ff31ffe ]--- mmcblk0: error -84 transferring data, sector 1433728, nr 8, card status 0xd00 end_request: I/O error, dev mmcblk0, sector 1433729 Buffer I/O error on device mmcblk0p3, logical block 0 lost page write due to I/O error on mmcblk0p3 EXT3 FS on mmcblk0p3, internal journal EXT3-fs: mounted filesystem with writeback data mode. VFS: Mounted root (ext3 filesystem) on device 179:3. Freeing init memory: 92K Populating /dev using udev: done Initializing random number generator... done. Starting network... can't open /dev/ttySAC0: No such file or directory can't open /dev/ttySAC0: No such file or directory can't open /dev/ttySAC0: No such file or directory mmcblk0: error -84 transferring data, sector 2486376, nr 8, card status 0xd00 end_request: I/O error, dev mmcblk0, sector 2486377 Buffer I/O error on device mmcblk0p3, logical block 131581 lost page write due to I/O error on mmcblk0p3 mmcblk0: error -84 transferring data, sector 2486384, nr 88, card status 0xd00 end_request: I/O error, dev mmcblk0, sector 2486385 end_request: I/O error, dev mmcblk0, sector 2486392 end_request: I/O error, dev mmcblk0, sector 2486400 end_request: I/O error, dev mmcblk0, sector 2486408 end_request: I/O error, dev mmcblk0, sector 2486416 end_request: I/O error, dev mmcblk0, sector 2486424 end_request: I/O error, dev mmcblk0, sector 2486432 end_request: I/O error, dev mmcblk0, sector 2486440 end_request: I/O error, dev mmcblk0, sector 2486448 end_request: I/O error, dev mmcblk0, sector 2486456 end_request: I/O error, dev mmcblk0, sector 2486464 mmcblk0: error -84 transferring data, sector 2486480, nr 224, card status 0xd00 Any idea?
I replaced the SDCARD and can get away from the I/O error. But I am facing another strange problem: NET: Registered protocol family 17 s3c-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). s3c-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). mmc0: new SDHC card at address 8fe4 s3c2410-rtc s3c2410-rtc: setting system clock to 2005-07-02 20:13:08 UTC (1120335188) Waiting for root device /dev/mmcblk0p3... mmcblk0: mmc0:8fe4 SD04G 3.69 GiB mmcblk0: p1 p2 p3 kjournald starting. Commit interval 5 seconds EXT3 FS on mmcblk0p3, internal journal EXT3-fs: mounted filesystem with ordered data mode. VFS: Mounted root (ext3 filesystem) on device 179:3. Freeing init memory: 156K Populating /dev using udev: done Initializing random number generator... done. Starting network... can't open /dev/ttySAC0: No such file or directory can't open /dev/ttySAC0: No such file or directory can't open /dev/ttySAC0: No such file or directory can't open /dev/ttySAC0: No such file or directory can't open /dev/ttySAC0: No such file or directory can't open /dev/ttySAC0: No such file or directory can't open /dev/ttySAC0: No such file or directory can't open /dev/ttySAC0: No such file or directory can't open /dev/ttySAC0: No such file or directory I am sure that I already have the ttySAC0 node on the /dev folder Do you have any clue about that, dave? Thanks
While in minicom do a <printenv> and see what environment variables you have. Where did you get the u-boot.bin or u-boot-variant.bin from? Also, I am confused here . . . the Product Comparison for the micro2440 says that it doesn't have a SD card slot.
The micro2440 does have an SD card slot, it's just in the product comparison you need to look at the micro SDK-board rather than the stamp module, but it is confusing. Phil
OK, now I am able to get the console working when booting from SDCARD. The thing is when the system is booted, all the /dev/ttySACx node disappear, and the /dev/s3c2410_serialx show up. I don't know why. It never happen when I boot from NAND flash. I had to replace this line on the etc/inittab file ttySAC0::respawn:/sbin/getty -L ttySAC0 115200 vt100 # GENERIC_SERIAL to: s3c2410_serial0::respawn:/sbin/getty -L s3c2410_serial0 115200 vt100 Hope that will help for other micro2440 SDK users :) My old SDCARD work fine with my PC, my camera but could not work with the 2440 board. May be it is a bug in the MMC driver. May be someone can fix it. :D Now, it is time for the CUPS and HPLIP
