Tslib.
Having another go at trying to cross-compile Tslib. All I see to be able to
generate are v5TE binaries rather than v4t.
I have -march=armv4t just about everywhere, as you will see below:
#!/bin/bash
export PATH=/usr/local/arm/4.3.2/bin:$PATH
# general cross-compile
export CROSS_COMPILE=arm-none-linux-gnueabi-
export CC="${CROSS_COMPILE}gcc -march=armv4t -mtune=arm920t"
export CXX=${CROSS_COMPILE}"g++"
export AR=${CROSS_COMPILE}"ar"
export AS=${CROSS_COMPILE}"as"
export RANLIB=${CROSS_COMPILE}"ranlib"
export LD=${CROSS_COMPILE}"ld"
export STRIP=${CROSS_COMPILE}"strip"
echo " ****************** Configuring tslib ********************* "
./autogen-clean.sh
export ac_cv_func_malloc_0_nonnull=yes
./autogen.sh
CC=/usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-gcc CFLAGS="-O0
-msoft-float -D__GCC_FLOAT_NOT_NEEDED -march=armv4t -mtune=arm920t"
CXX="/usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-g++ -O0 -msoft-float
./configure --host=arm-none-linux-gnueabi --target=arm-none-linux-gnueabi
-enable-static=no -enable-shared=yes -prefix /usr/local/tslib
make
sudo make install
I found I needed both
and
to get it to compile properly. I have tried doing <make clean> and <make
distclean>.
Also, if I enable-static=yes I get ranlib problems, but I will leave that
for later.
Anyone have any suggestions why it is not being build for the correct
architecture? Using Ubuntu 10.04 and 4.3.2 from FriendlyArm.
Thanks,
Dave
