I could not get my USB drive mounted. What command do I use. It was working earlier with udisk. But now I have flashed the latest root_qtopia-128M.img in the download section and udisk does not exist. How do I auto mount it. --- This is what I see when I insert a USB drive [root@FriendlyARM /dev]# usb 1-1.1: new full speed USB device using s3c2410-ohci and address 4 usb 1-1.1: New USB device found, idVendor=05dc, idProduct=a712 usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 1-1.1: Product: JD Lightning II usb 1-1.1: Manufacturer: Lexar usb 1-1.1: SerialNumber: 00027D07225753241107 usb 1-1.1: configuration #1 chosen from 1 choice scsi0 : SCSI emulation for USB Mass Storage devices scsi 0:0:0:0: Direct-Access Lexar JD Lightning II 1100 PQ: 0 ANSI: 0 CCS sd 0:0:0:0: Attached scsi generic sg0 type 0 sd 0:0:0:0: [sda] 1957888 512-byte logical blocks: (1.00 GB/956 MiB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Assuming drive cache: write through sd 0:0:0:0: [sda] Assuming drive cache: write through sda: sd 0:0:0:0: [sda] Assuming drive cache: write through sd 0:0:0:0: [sda] Attached SCSI removable disk
USB Flash drive mounting issue
ok..I figured it out. But now how do I automount. I do not see fstab [root@FriendlyARM /]# mount /dev/sda /mnt yaffs: dev is 8388608 name is "sda" yaffs: passed flags "" yaffs: Attempting MTD mount on 8.0, "sda" yaffs: dev is 8388608 name is "sda" yaffs: passed flags "" yaffs: Attempting MTD mount on 8.0, "sda" FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
I can mount a 1GB drive. But cannot mount 8GB. Log below.. please Help! usb 1-1.2: new full speed USB device using s3c2410-ohci and address 7 usb 1-1.2: New USB device found, idVendor=03f0, idProduct=3307 usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 1-1.2: Product: v125w usb 1-1.2: Manufacturer: HP usb 1-1.2: SerialNumber: 3S9A170500E9 usb 1-1.2: configuration #1 chosen from 1 choice scsi3 : SCSI emulation for USB Mass Storage devices scsi 3:0:0:0: Direct-Access HP v125w 1.00 PQ: 0 ANSI: 2 sd 3:0:0:0: Attached scsi generic sg0 type 0 sd 3:0:0:0: [sda] 15654848 512-byte logical blocks: (8.01 GB/7.46 GiB) sd 3:0:0:0: [sda] Write Protect is off sd 3:0:0:0: [sda] Assuming drive cache: write through sd 3:0:0:0: [sda] Assuming drive cache: write through sda: sda1 sd 3:0:0:0: [sda] Assuming drive cache: write through sd 3:0:0:0: [sda] Attached SCSI removable disk [root@FriendlyARM /]# mount /dev/sda /mnt yaffs: dev is 8388608 name is "sda" yaffs: passed flags "" yaffs: Attempting MTD mount on 8.0, "sda" yaffs: dev is 8388608 name is "sda" yaffs: passed flags "" yaffs: Attempting MTD mount on 8.0, "sda" FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! mount: mounting /dev/sda on /mnt failed: Invalid argument [root@FriendlyARM /]#
