I have a problem of using arm2440 development board, that the mouse
pointer is not moving along with my touch action. It is steadly pointing on
the bottom of the screen only . Therefore i am not able to open any of the
menus shown in the development board. I have burnt linux kernel as well as
windows CE so many times.but still the same problem is existing. Please
reply me very soon , as i am very much busy with that development kit.
Thanks in advance
pblm with touch sensor
Ya i am using mini2440 dev board .It is interfaced with 3.5" TFT LCD Type - NL2432HC22-23B 240x320 pixels But i dont know which type of touch panel is using here in my development board. Thankyou for ur reply
I don't understand your last sentence. You have the older NEC touchscreen. FYI it is a resistive type touchscreen. What happens if you put in this zImage? http://www.friendlyarm.net/dl.php?file=linux-zImage_20100609.zip Are you trying to compile your own kernel?
Actually i hav burned zImage_T35, which i got along with development kit. It worked well till last day.I got the problem from yesterday onwards. Thatswhy, i doubted touchsreen. Can i try with the kernel you mentioned above?
