hi, i having a mini6410 3.5 TFT 128 Mb flash, 128Mbyte Ram, just downloaded the CE6 images but having a boot problem it show the boot logo hang.. from the serial port it show "Reading....NK length Error". the ce6 images from DVD is working OK. can anybody help me to resolve this problem thank in advance
boot problem CE6 images 20101121
Hello Bong Kieng Foh, I am also facing same problem with mini6410 7"TFT, 1G nand flash, and 256mb ram. Did u solved the issue? if yes then what was your remedy for this problem.
Hi,I also have a problem with the images (Mini 6410 256MB RAM, 256MB flash, 7" LCD). As said, the image from the DVD is working correctly. However when I try to build my custom image (mainly because I need to localize it to other languages) I get a couple hundred warnings (not errors) and the image does not boot. I have installed a completely fresh Visual Studio with Platform builder and all updates, tried both under WinXP and Win7 x64, using the Mini6410-WinCE6-Suite-1142. All was working correctly with some older version about half a year back. So if anyone has some idea how to make it work, I would greatly appreciate it.
