Anybody help me? ************************************************************************** owner@ubuntu:~$ cd bin owner@ubuntu:~/bin$ cd FriendlyARM/ owner@ubuntu:~/bin/FriendlyARM$ cd android/ owner@ubuntu:~/bin/FriendlyARM/android$ cd kernel/ owner@ubuntu:~/bin/FriendlyARM/android/kernel$ cp config_mini2440 .config owner@ubuntu:~/bin/FriendlyARM/android/kernel$ make menuconfig scripts/kconfig/mconf arch/arm/Kconfig *** End of Linux kernel configuration. *** Execute 'make' to build the kernel or try 'make help'. owner@ubuntu:~/bin/FriendlyARM/android/kernel$ make zImage CHK include/linux/version.h make[1]: `include/asm-arm/mach-types.h' is up to date. CHK include/linux/utsrelease.h CALL scripts/checksyscalls.sh <stdin>:1097:2: warning: #warning syscall fadvise64 not implemented <stdin>:1265:2: warning: #warning syscall migrate_pages not implemented <stdin>:1321:2: warning: #warning syscall pselect6 not implemented <stdin>:1325:2: warning: #warning syscall ppoll not implemented <stdin>:1365:2: warning: #warning syscall epoll_pwait not implemented CHK include/linux/compile.h CC fs/binfmt_aout.o fs/binfmt_aout.c: In function 'load_aout_binary': fs/binfmt_aout.c:317:30: error: 'SEGMENT_SIZE' undeclared (first use in this function) fs/binfmt_aout.c:317:30: note: each undeclared identifier is reported only once for each function it appears in make[1]: *** [fs/binfmt_aout.o] Error 1 make: *** [fs] Error 2 owner@ubuntu:~/bin/FriendlyARM/android/kernel$
binfmt_aout.c error: 'SEGMENT_SIZE' undeclared
Hi Marek Thanks for your help. compiler = Sourcery G++ The path is ready added. From my picture, it should able to run compiler(Sourcery G++) & access code file. But compiler say 'SEGMENT_SIZE' undeclared (first use in this function). Seem something necessary to define before compile. From binfmt_aout.c(line 99) Seem to define "START_DATA". Which is relate to line 317 *************************************** #if defined(__alpha__) # define START_DATA(u) (u.start_data) #elif defined(__arm__) # define START_DATA(u) ((u.u_tsize << PAGE_SHIFT) + u.start_code) #elif defined(__sparc__) # define START_DATA(u) (u.u_tsize) #elif defined(__i386__) || defined(__mc68000__) || defined(__arch_um__) # define START_DATA(u) (u.u_tsize << PAGE_SHIFT) #endif #ifdef __sparc__ # define START_STACK(u) ((regs->u_regs[UREG_FP]) & ~(PAGE_SIZE - 1)) #else # define START_STACK(u) (u.start_stack) #endif
Hi, well try to compile this way: make ARCH=arm CROSS_COMPILE=<prefix to your cross compiler (without gcc) e.g. arm-linux- marek
marek right. initially in Makefile is "CROSS_COMPILE=arm-linux-" then modify it to be CROSS_COMPILE=arm-none-linux-???(I am not sure) After that it can beginning to complie. But shop in 'SEGMENT_SIZE' undeclared ******************************************* CC fs/binfmt_aout.o fs/binfmt_aout.c: In function 'load_aout_binary': fs/binfmt_aout.c:317:30: error: 'SEGMENT_SIZE' undeclared (first use in this function) fs/binfmt_aout.c:317:30: note: each undeclared identifier is reported only once for each function it appears in make[1]: *** [fs/binfmt_aout.o] Error 1 make: *** [fs] Error 2
check if arm-none-linux-gcc is in your patch (which arm-none-linux-gcc should give some path). Also ARCH=arm is set? Could you post sources what you try to compile? marek
Marek Thanks for your help. Do you mean below? **************************** export KBUILD_BUILDHOST := $(SUBARCH) ARCH ?= arm #CROSS_COMPILE ?= arm-linux- CROSS_COMPILE ?= arm-none-eabi- **************************** For source issue, the whole set source file is very big. or you mean "Makefile"? Which is attached.
For source, please download with below link. http://www.friendlyarm.net/dl.php?file=android-kernel_20090825.tgz http://www.friendlyarm.net/dl.php?file=android-fs_20090825.tgz
I find some info. http://moto.debian.org.tw/viewtopic.php?p=56720 & http://hi.baidu.com/yatusiter/blog/item/6df3e8507a6e04541038c2a5.html Who said something necessary be selected in make menuconfig to support a.out. Executable file formats ---> <M> Kernel support for a.out and ECOFF binaries What is the mean/ function of it"Kernel support for a.out and ECOFF binaries"? Also what different between "<M>" & "<*>"? Since the initial state is <*>.
Well your problem could be fixed: 1. rename in kernel directory config_mini2440 to .config 2. make ARCH=arm CROSS_COMPILE=arm-none-eabi- You will have no problems with compilation (at least I don't have ;)). marek
