Hello All
I am facing a problem while adding add a new command to u-boot.
Could you please any one can help.
What i followed.
1.i created a file under common folder under u-boot with name cmd_xyz.c
2.i modified makefile in common folder :
COBJS-y += cmd_xyz.o
It was successfully complied and generated objectfile
arm-linux-gcc -g -Os -fno-common -ffixed-r8 -msoft-float -D__KERNEL__
-DTEXT_BASE=0x80e80000
-I/home/alexander/projects/overo/u-boot/u-boot-2009.11/include -fno-builtin
-ffreestanding -nostdinc -isystem
/home/alexander/projects/overo/cross_compile/armv7a/bin/../lib/gcc/arm-angstrom-
linux-gnueabi/4.3.3/include
-pipe -DCONFIG_ARM -D__ARM__ -marm -mabi=aapcs-linux -mno-thumb-interwork
-march=armv5 -Wall -Wstrict-prototypes -fno-stack-protector -o cmd_xyz.o
cmd_xyz.c -c
Static library is creaed in this common folder with name:libcomman.a
arm-linux-ar crv libcommon.a cmd_bdinfo.o cmd_boot.o cmd_bootm.o
cmd_console.o cmd_ext2.o cmd_fat.o cmd_i2c.o cmd_itest.o cmd_jffs2.o
cmd_load.o cmd_mem.o cmd_misc.o cmd_mmc.o cmd_nand.o cmd_net.o cmd_nvedit.o
cmd_pcmcia.o cmd_source.o cmd_spi.o cmd_ximg.o cmd_xyz.o command.o
console.o dlmalloc.o env_common.o env_nand.o exports.o flash.o hush.o
image.o main.o memsize.o s_record.o stdio.o xyzModem.o
cmd_xyz.c file looks like this:
#include <common.h>
#include <command.h>
#include <environment.h>
#include <linux/stddef.h>
#include <malloc.h>
int do_go (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
ulong addr, rc=1;
int rcode = 0;
if (argc < 2) {
cmd_usage(cmdtp);
return 1;
printf ("## Application Successfuly run & terminated");
return rcode;
U_BOOT_CMD(
go, CONFIG_SYS_MAXARGS, 1, do_go,
"start application at address 'addr'",
"addr [arg ...]\n - start application at address 'addr'\n"
" passing 'arg' as arguments"
But still i could not find go command.
Reasons:
1.do_go still is no there in System.map file
From System.map file user commnad is not there between (__u_boot_cmd_start
and __u_boot_cmd_end)
In code
80e9f53c A __u_boot_cmd_start
80e9f53c D __u_boot_cmd_nandecc
80e9f558 D __u_boot_cmd_bootm
80e9f574 D __u_boot_cmd_boot
80e9f590 D __u_boot_cmd_bootd
80e9f5ac D __u_boot_cmd_saveenv
80e9f5c8 D __u_boot_cmd_editenv
80e9f5e4 D __u_boot_cmd_printenv
80e9f600 D __u_boot_cmd_setenv
80e9f61c D __u_boot_cmd_run
80e9f638 D __u_boot_cmd_version
80e9f654 D __u_boot_cmd_echo
80e9f670 D __u_boot_cmd_test
80e9f68c D __u_boot_cmd_exit
80e9f6a8 D __u_boot_cmd_help
80e9f6c4 D __u_boot_cmd_question_mark
80e9f6e0 D __u_boot_cmd_showvar
80e9f6fc A __u_boot_cmd_end
common/command.c
cmd_tbl_t *find_cmd (const char *cmd)
int len = &__u_boot_cmd_end - &__u_boot_cmd_start;
return find_cmd_tbl(cmd, &__u_boot_cmd_start, len);
cmd_tbl_t *find_cmd_tbl (const char *cmd, cmd_tbl_t *table, int table_len)
cmd_tbl_t *cmdtp;
cmd_tbl_t *cmdtp_temp = table; /*Init value */
const char *p;
int len;
int n_found = 0;
* Some commands allow length modifiers (like "cp.b");
* compare command name only until first dot.
len = ((p = strchr(cmd, '.')) == NULL) ? strlen (cmd) : (p - cmd);
for (cmdtp = table;
cmdtp != table + table_len;
cmdtp++) {
if (strncmp (cmd, cmdtp->name, len) == 0) {
if (len == strlen (cmdtp->name))
return cmdtp; /* full match */
cmdtp_temp = cmdtp; /* abbreviated command ? */
n_found++;
if (n_found == 1) { /* exactly one match */
return cmdtp_temp;
return NULL; /* not found or ambiguous command */
My doubts:
Where i have to search and which files?
what export.c(in common folder)will do?
Please Help any one.
ALexander
Hi, Is it possible to use the command infrastructure to add my own application, and instead of going no os, I do it on top of uboot? I get some flash access and ethernet access (which interests me). Am I correct, will this work or am I missing something big? Thanks, Kobus
