Hi, I just received some boards with the display marked as LCD-X35. I tested one of them with WinCE generated with the "T35" option, and the display doesn't show any image at all. Then I generated the OS with the "N35" option. Now the LCD shows image, but it is not centered and some part of it is out of frame. I was wonder how could I solve this, as it seems that is not official driver support for this display, at least in the download page. Thanks for reading and your help.
WinCE driver for LCD-X35
Hi, As I could find other thread where it is said that Linux image has been successfully modified to work with LCD-X35, I tested editing the N35 section in s3c2440a_lcd.h file, by setting the values according with this http://pastebin.com/ZZCVxF9x link: #if defined(LCD_N35) #define LCD_PIXCLOCK 4 #define LCD_RIGHT_MARGIN 26 #define LCD_LEFT_MARGIN 1 #define LCD_HSYNC_LEN 5 #define LCD_UPPER_MARGIN 1 #define LCD_LOWER_MARGIN 5 #define LCD_VSYNC_LEN 9 Please, note that I left LCD_PIXCLOCK in the same value as NEC35 (4), as the value (170000) in the Linux example is out of the range of values found in s3c2440a_lcd.h (2 and 4 in all cases). Somebody, maybe at FriendlyARM could clarify me what values should I set to use LCD-X35? Thanks in advance and best regards.
Anyone?. Maybe someone at FriendlyARM, like Mindee. I just need the LCD parameters (LCD_PIXCLOCK, LCD_RIGHT_MARGIN, LCD_LEFT_MARGIN, LCD_HSYNC_LEN, LCD_UPPER_MARGIN, LCD_LOWER_MARGIN, LCD_VSYNC_LEN) in order to edit "s3c2440a_lcd.h". Thanks
If it is helpfull, I could make the LCD work just by replacing the LCD files of my current BSP with the files in the BSP that you find in the chinese site. Thanks.
Maybe I found. In the chinese site there is Mini2440-CE6-Suite-1038.zip. Install it and then you find the X35 define values.
You can replace the LCD related files with the files you can find in the "chinese" BSP: http://arm9download.cncncn.com/mini2440/wince6/Mini2440-CE6-Suite-1038.zip
