I'd like to try and recompile the tslib in the linux rootfs to try and couple of options out, can you provide the source code of your input module. Or better still the whole folder you use to compile it. Thanks Andrew
friendlyarm-ts-input.so source code
Hi, I modify touch screen driver in linux source, so touch screen can work with any standard tslib as /dev/input/event0 now. This driver doesn't need friendlyarm-ts-input.so library and worked good with buildroot file system. target board is mini6410. It's bad that friendly-arm tslib not shared for users. REZA
