hi everybody i want to know, can i use INNOLUX AT080TN42 TFT LCD for mini2440 or mini6410 datasheet url: http://www.vitrolight.com/specs/AT080TN42.pdf thanks a lot.
8" Display
The vitro display uses an ST driver, so I don't know if the signals are compatible with the NEC (Nxx) or the Toppoly (Txx) drivers, even if they are, the vitro display has a different kind of FRC cable, so you would need to make a small pcb to change the signal order. Having said that, there is a good possibility that it would be compatible, because all three displays have the same number of pins, the same number of signals, and the same operating voltages. Let us know if you do get it to work after a bit of hacking. Best of luck.
