Hi every body. When i loaded for mini2440 with Vivi -> kernel -> root yaffs, i did that successfully but not for the screen. The linux screen is slightly drift into right about 5mm, that makes me could not use scrool bar at all! all you know that problem? please help me, thank your helping very much.
screen of linux is slightly drifted
by the way, i have picture for that problem, please watch it and help me http://seablogs.zenfs.com/u/g_5BKKWFGB6gdayTDXEyNmY6KQ--/photo/201012101...
If there is an offset then you use the wrong zImage. http://www.friendlyarm.net/forum/topic/107 http://www.friendlyarm.net/forum/topic/307
Oh, thank you very much. (I should read the forum carefully before post the
question :) )
I solved the problem, I should use kernel which support T35 instead of N35
as before.
And i find in the forum that, if we would like to align more the screen, we
will modify this file:
/opt/FriendlyARM/mini2440/linux-2.6.32.2/arch/arm/mach-s3c2440#
gedit mach-mini2440.c
Thanks all.
