Dear Friendlyarm, I managed to flash the test firmware and it works like a charm. I want to flash the qtopia install back but i cant find any image. You describe to flash the root_qtopia.img file but there are only tarbal images. This is the chapter (linux_download.pdf) downloading filesystem to the board: You now need to install yaffs, press the “y” key and then return on the PC, the screen will display “USB host is connected. Waiting a download”. Click the USB Port from the menu and select the Transmit/Restore option. The screen will now ask you to select a file to transmit. Choose the “root_qtopia.img” file. Then click OPEN. I like this board very much ! Jerry
you can download link below. http://www.arm123.com.cn/linux/linux-images-20090616.rar
Hi All, This is Babu, i have loaded QT in MINI2440 and not able to boot QT can anybody suggest to how to save QT in NAND flash and how to boot QT. while booting getting a warning.. Warning : This binary is not compressed linux kernel image
