Hi guys, SD-Flasher does not see my 2GiB SD card. SD card is formatted with FAT32. Does anybody have the same problem ? Can I use some other software insted of sd-flasher ? Regards, Vadim
SD-Flasher does not see SD card
In my case, sd-flasher can see the SD card (8GB SDHC),but when I flash supervivi this happens: 1) sd-flasher returns inmediatly with ok. 2) there is nothing written in the SD card (searching with Windows explorer) Can someone help me?
I think you use card reader on board of PC or Notebook . Please try to use SD card reader and re-do again http://www.minidevs.com/Mini6410/Bootloader.html Napong@TEE
the problem is that the SD Card reader is internal, the SD-flasher only can work with a USB-SD Card Readers, this solution can help you
