Hi all, here I come with another question. When I plug a USB memory stick in my MINI2440, and try to manually mount it, I receive an "Invalid argument" error. The stick is 8 GB FAT32; when I plug it, the /dev/sda appears and, if I launch the dmesg command, I can see that it's correctly recognized. I try to mount it in /udisk, that exists. The commands I tried are "mount /dev/sda /udisk" and "mount -t vfat /dev/sda /udisk". Both fail. Somebody had the same problem in the past? Any hint? Thanks in advance!
USB stick on MINI2440
Hi, unfortunately I don't have the mini2440 on my desk in this moment, but I think that it's 2.6.29. The command I type it's right, ain't it? Or maybe I should provide more options? Thanks
Yes command is fine and could you post some last lines from dmesg output? Maybe you don't have all modules installed properly or compiled. marek
Possibly you have usb stick without partitions? sometimes windows make such a things. Add some partition or mount /dev/sda directly.
Hi all, I've tried with another stick, that is FAT, and everything is working fine. I've mounted manually with mount /dev/sda /udisk command. Gotta understand why I've troubles with FAT32, but, at the moment, it's ok. Thanks for hints!
