Hi, I've had my mini2440 board for about one year now and I experience this problem again and again: I install software to the NAND, be that linux or anything else. Then I simply use, compile my software and copy it to the mini and everything works like a charm! Then I leave the board laying arround for some time (days, weeks) and start it again and my NAND is faulty! It does not boot anymore. I thought maybe the battery on the board was flat but it's good. I read that some boards have problems with the power supply. Could this be causing it? I'm quite unhappy with this because I dont want to reinstall all my stuff over and over again, also what I'm developing is meant to be realiable! Have you experienced this? Any ideas what I can do?
NAND problems....
Hi, Electricity of human body, is one of the most important enemies of electronic modules. It may cause, unpredictable behavior of boards. Another enemies are mechanical pressure or shock during installation (that may cause disconnections in pcb layers), continues heat on parts, ... Have you protected your boards ? best regards www.dadehabzar.ir
Well my board is sitting on my desk :). Shouldn't be too much hazard here. Btw my NAND is 128mb deep and it's a HYNIX chip!
I always use at least two (normal three) sample boards for benchmarking. by the way, ten years ago, the brand of chips, was a critical issue, but now-days most of them are enough good for most applications. regarding power supply, only few parts of mini2440 board use 5V (directly from plugin). you can check your power lines (5V, 3.3V, 1.8V with dedicated grounds) by monitoring them (using digital oscilloscope) during start-up of board. they should be stable and noise level should be about 50mV. best regards www.dadehabzar.ir
