I am building a kernel image with drivers. I have copied my driver in drivers/char I have modified the makefile and Kconfig file. when i do make zImage i am getting the below error. CHK include/linux/compile.h LD vmlinux.o net/built-in.o(.text+0x10ffc): In function `dev_open': : multiple definition of `dev_open' drivers/built-in.o(.text+0x2aa14): first defined here arm-linux-ld: Warning: size of symbol `dev_open' changed from 32 in drivers/built-in.o to 284 in net/built-in.o net/built-in.o(.text+0x11d9c): In function `dev_ioctl': : multiple definition of `dev_ioctl' drivers/built-in.o(.text+0x2aa54): first defined here arm-linux-ld: Warning: size of symbol `dev_ioctl' changed from 536 in drivers/built-in.o to 2084 in net/built-in.o make: *** [vmlinux.o] Error 1 Please guide me..
Error while building kernel image
Could you please post you driver code? Possibly you use dev_* functions which are already used. Add before dev_open and dev_ioctl static keyword.
