I am new to friendlyARM boards & trying to set up Angstrom image on the mini2440 with 7in LCD. I used the pre-built Angstrom console only image from - http://code.google.com/p/mini2440/downloads/list As indicated by 'widyo'(http://www.friendlyarm.net/forum/topic/1339) , I installed the X11 package using opkg install. The problem starts when I try to start X11 using command # X :0.0 & ___________________________________________________________________ _XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6 _XSERVTransOpen: transport open failed for inet6/mini2440:0 _XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6 X.Org X Server 1.5.3 Release Date: 5 November 2008 X Protocol Version 11, Revision 0 Build Operating System: Linux 2.6.24-1-amd64 x86_64 Current Operating System: Linux mini2440 2.6.29 #1 Thu Apr 2 19:52:50 BST 2009 armv4tl Build Date: 01 February 2009 05:12:51AM Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.0.log", Time: Sun Nov 28 03:21:40 2010 (==) Using config file: "/etc/X11/xorg.conf" Primary device is not PCI (EE) AIGLX error: dlopen of /usr/lib/dri/swrast_dri.so failed (/usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory) (EE) GLX: could not load software renderer ___________________________________________________________________ All I can see is a blank white screen (looks like a X11 screen) with cross bar at the centre; No Desktop, nor the touchscreen responding. BTW, I have verified seperately using ts_test, display & touchscreen calibration works fine. Can you please let me know if I need to, (a) configure the display LCD specifically for X11 using xorgconf? How? (b) install a windows manager to get the complete UI look & feel. If so, which one? (c) add scripts in /etc/rc5/ to make X11 kick-in during the startup. This would give me the regular desktop effect on bootup. I don't have the OE sources to rebuild the filesystem, so preferably would prefer to make modification in the runtime configuration file to sort out things. I boot the filesystem using SD-Card, and with the following bootargs, root@mini2440:~# cat /proc/cmdline console=ttySAC0,115200 mini2440=1tb rootfstype=ext3 root=/dev/mmcblk0p3 rw rootwait Regards, Subbu
