Hi all. I have a Mini6410 and in the DVD comes 2 files of UBoot, so my question is: What is the difference between u-boot_nand.bin and u-boot_sd.bin? Thanks.
Difference between u-boot_nand - u-boot_sd?
u-boot_sd.bin is the bootloader for sd card ..so u can boot u-boot from sd card (but for this first superboot and then u-boot_sd.bin is to be flshed to sd card using sd-flasher.exe). u-boot_nand.bin is the bootloader for nand..so using this u-boot from nand can be booted (using u-boot from sd card u-boot_nand.bin can be flashed to nand directly using dnw.exe)..please refer user manual also for details
Hi, thanks for reply. To boot from SD I flash Superboot into the SD, then I can boot from it and flash Uboot_nand in to the NAND, then upload the kernel image to NAND, run the kernel and load the filesystem(Debian) from SD,no problem to here. The problem it's if I flash uboot_sd into the SD becouse nothing happen when I try to boot from SD, to do this I used SD-Flasher.exe. I want to boot from SD and run the system(Debian) that I have configure in to the SD. I need to flash Superboot and Uboot_sd into the SD? Thanks :)
superboot first checks u-boot in sd card and if not found it boots u-boot from nand. that is why u could update images in nand using the u-boot from nand. In case u want u-boot to boot from sd card flash superboot and u-boot_sd to sd card using sd-flasher.exe. Copy the image folder containing kernel image and using script FriendlyARM.ini configure it to boot kernel from sd card. now change the S2 switch to 'SDBOOT' and power on the board. it boots u-boot from sd card. Then u can follow the procedure of booting kernel from sd card
Thanks again for answer.
I flashed superboot and ubood_sd into the SD but when I boot from NOR I got
a message error
U-Boot 1.1.6 (Sep 17 2010 - 11:53:40) for FriendlyARM MINI6410
CP
U: S3C6410@532MHz
Fclk = 532MHz, Hclk = 133MHz, Pclk = 66MHz, Serial = CLKUART (SYNC
Mode)
Board: MINI6410
DRAM: 128 MB
Flash: 0 kB
NAND: 1024 MB
MMC:
error found: 0001
are u using mmc card for booting u-boot. bacause i also tried mmc card and it doesnot seem to work. please try the same procedure with SD card. only SD card seem to work..
I haven't a SD card only MicroSD of 8GB Class 10. I was read in some sites that Uboot suport boot from mmc but the version for Mini6410 doesn'n work.
