How do I have to set time that the realtime clock is set? I set time with date 2009.12.03-20:00 but after a reboot the time is lost and some other time from 2005 is restored. How can I fix that? thanks a lot
Real time clock
Does this help? Search for <BusyBox commands>
hwclock
hwclock [-r|--show] [-s|--hctosys] [-w|--systohc] [-l|--localtime]
[-u|--utc] [-f FILE]
Query and set hardware clock (RTC)
Options:
-r Show hardware clock time
-s Set system time from hardware clock
-w Set hardware clock to system time
-u Hardware clock is in UTC
-l Hardware clock is in local time
-f FILE Use specified device (e.g. /dev/rtc2)
Just read the source of the "hwclock" command and you will know how to set the clock from inside your own program.
