hi how can I terminate hello (gui) application from terminal? I want to use it in a bash file b.r.
First get the name of the process from the terminal using ps. You will probably get 'hello'. use "pidof hello" to get the process id of hello. For example 1234. then use "kill -9 1234" to kill it. Other way, once you get the process name, use: killall -9 hello This will kill all processes by the name hello. Good luck.
