Hi, I am a new in WINce. I just bought one PocketPC (NOname, made in China) with ARM CPU and WINce5.0. What I am trying is to run USB to RS232 cable. When I plug the cable it ask me for the name of the driver. So I downloaded the .CAB file (for WINce), but when I try to run the file it sayes that it is not for this device. I tryed this for two difarent cables. One with pl2303 chip and another with uc232a chip, but nothing. I dont know where the problem comes from, should I install something else, or if you know a working cable and driver, pls help. Thanks
USB to RS232
This might work: http://www.prolific.com.tw/support/files//IO%20Cable/PL-2303/Drivers%20-... Are you planning to use the friendlyarm from the pocketpc? It could be easier through ssh or something similar, if the device has wifi that is.
here is the device with all specifications: http://www.dealextreme.com/details.dx/sku.39551 Thanks for the driver, I will try it later and post the result
the application cannot run on this device type. Please install the application specific to this device type.
