Problem to execute a simple example in mini2440 with a factory
configuration :
I have a mini2440 T35 with a factory configuration ( linux + Qtopia ).
I begin to compile hello.c example exist in the DVD :
=> hello.c :
#include <stdio.h>
int main(void) {
printf("hello, FriendlyARM!\n");
=> Makefile :
CROSS=arm-linux-gnueabi-
all: hello
hello:
$(CROSS)gcc -o hello hello.c
clean:
@rm -vf hello *.o *~
Rq : I try also with the manual compilation.
=> I have a following version of arm-linux :
- When i type the following commande :
# arm-linux-gnueabi-gcc -v
I have almost responded with :
Using built-in specs.
COLLECT_GCC=arm-linux-gnueabi-gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabi/4.5.1/lto-wrapper
Target: arm-linux-gnueabi
gcc version 4.5.1 (Ubuntu/Linaro 4.5.1-7ubuntu1)
=> And i add the executable mode to the file :
[root@FriendlyARM plg]# chmod 777 hello
====>> My problem is, when i execute the hello example, i get the following
answer :
[root@FriendlyARM plg]# ./hello
Illegal instruction
or :
[root@FriendlyARM plg]# sh hello
hello: line 1: syntax error: word unexpected (expecting ")")
RQ : the same comportment when using a flash disk or SDcard or another
platform such as fedora or when I change the compiler as CodeSourcery.
Thank you,
Haithem.
Problem to execute a simple exemple in mini2440(factory config)
Have you tried compiling with the gcc-arm which came with your device or the one which is downloadable from this website?
I mean this one: http://www.friendlyarm.net/dl.php?file=arm-linux-gcc-4.3.2.tgz which can be found on this page: http://www.friendlyarm.net/downloads
Now i wand to use the NFS and TFTP server, I tried several times without success. I use the command ubout to configure the mini2440 to load kernel with TFTP server and file system with NFS server and i use ubuntu 10.10
