Hello! I don't know why supervivi does not starts any more in my mini6410. I can see the linux console in hyperterminal when I turn on the mini with the switch at nand side but when I do it with the switch in the other position, I don't get anything in hypeterminal. What sould I do? I guess I must download again the supervivi to nor flash but I dont have the supervivi for mini6410 neither htag software, and if I have them I dont know how to do it for this mini. Anyone could help me with this?? Thanks!!
supervivi doesn't start in mini6410
blake, First, check that you put the switch in the NOR position and after firing up DNW and connecting to serial comms, then turn the power on the dev board. If that doesn't show anything . . . it looks like you have deleted SuperVivi from NOR. Sooner or later you will have to learn this skill. So, go to: http://www.friendlyarm.net/dl.php?file=download.pdf I think that should be the "JTAGing the NOR" document and then get H-JTAG on downloads page. Any problems search <H-JTAG> and get back with your errors. Good luck
I have a mini6410 board and the bootloader it's Uboot not Supervivi. To run Uboot in NOR use Superboot. Use SD-Flasher.exe(SO Windows) from the DVD to flash a SD with Superboot, run SD-Flasher, connect a SD to PC, format the SD(FAT32). In the SD-Flasher press the Scan button to detect the SD, select the SD in the list and then press the button Fuse. Connect the SD to the board switch to NOR and power on the board. Bye.
