hi how it is possible to upgrade s3c2440camera device driver for kernel mini2440(2.6.29.4) ? regards
update s3c2440camera device driver for kernel mini2440(2.6.29.4)
I did but
[root@FriendlyARM /]# cd sdcard
[root@FriendlyARM /sdcard]# ls
mjpg-streamer s3c2440camera.ko test_capture
[root@FriendlyARM /sdcard]# chmod u+x s3c2440camera.ko
[root@FriendlyARM /sdcard]# chmod u+x test_capture
[root@FriendlyARM /sdcard]# insmod s3c2440camera.ko
[root@FriendlyARM /sdcard]# ./test_capture
./test_capture: line 1: syntax error: "(" unexpected
I build with 2.6.32 and mini2440 is 2.6.29.4 version.
Well I try on my board works fine: ./test_capture Usage:./test_capture <device> <width> <height> <output_base> [number of frames] Check if you compile correctly.
kindly, what is your host kernel version and mini2440 kernel version ? could you please send me test_capture and s3c2440camera.ko files.
tanx your file does not work on my mini2440(2.6.29.4) [root@FriendlyARM /sdcard]# chmod u+x s3c2440camera.ko [root@FriendlyARM /sdcard]# insmod s3c2440camera.ko insmod: cannot insert 's3c2440camera.ko': invalid module format [root@FriendlyARM /sdcard]# chmod u+x test_capture [root@FriendlyARM /sdcard]# ./test_capture -sh: ./test_capture: not found [root@FriendlyARM /sdcard]#
I just updated mini2440-128 with vivi,zImage_t35 & root_gtopia.img (just downloaded from friendlyarm) but still the problem exist [root@FriendlyARM /]# chmod u+x s3c2440camera.ko [root@FriendlyARM /]# insmod s3c2440camera.ko insmod: cannot insert 's3c2440camera.ko': invalid module format do you use original image or have had modification on you mini2440 files?
{and I use FileZilla3 in binary transfer format; size of transferred files
from pc to mini2440 are the same}
Hi Are you sure you compiled the module with the rigth Linux kernel version ? Run objdump and verify if the generated code is ARM. You may be compiling the module with the gcc for Intel instead of the ARM cross compile.
root@dab-desktop:/home/dab/project/mini2440/s3c2440camera-r5# objdump -i test_capture BFD header file version (GNU Binutils for Ubuntu) 2.20.1-system.20100303 elf32-i386 (header little endian, data little endian) i386 a.out-i386-linux (header little endian, data little endian) i386 pei-i386 (header little endian, data little endian) i386 elf32-little (header little endian, data little endian) i386 l1om plugin elf32-big (header big endian, data big endian) i386 l1om plugin elf64-x86-64 (header little endian, data little endian) i386 pei-x86-64 (header little endian, data little endian) i386 elf64-l1om (header little endian, data little endian) l1om elf64-little (header little endian, data little endian) i386 l1om plugin elf64-big (header big endian, data big endian) i386 l1om plugin plugin (header little endian, data little endian) BFD: BFD (GNU Binutils for Ubuntu) 2.20.1-system.20100303 assertion fail ../../bfd/plugin.c:436 objdump: plugin: Bad value srec (header endianness unknown, data endianness unknown) i386 l1om plugin symbolsrec (header endianness unknown, data endianness unknown) i386 l1om plugin verilog (header endianness unknown, data endianness unknown) i386 l1om plugin tekhex (header endianness unknown, data endianness unknown) i386 l1om plugin binary (header endianness unknown, data endianness unknown) i386 l1om plugin ihex (header endianness unknown, data endianness unknown) i386 l1om plugin trad-core (header endianness unknown, data endianness unknown) root@dab-desktop:/home/dab/project/mini2440/s3c2440camera-r5#
makefile # If KERNELRELEASE is defined, we've been invoked from the # kernel build system and can use its language. # or specify your own in command line KERNELDIR =/opt/FriendlyArm/mini2440/linux-2.6.32.2 # where libtiff is compiled, only needed for tiff_capture TIFFDIR ?= ../tiff-3.9.2 EXTRA_CFLAGS += -I/opt/FriendlyArm/mini2440/linux-2.6.32.2 ifneq ($(KERNELRELEASE),) obj-m := s3c2440camera.o s3c2440camera-objs := s3c2440_ov9650.o sccb.o s3c2440camif.o # Otherwise we were called directly from the command # line; invoke the kernel build system. else PWD := $(shell pwd) default: bash ./ARM-Linux-GCC-4.3.2.sh $(MAKE) -C $(KERNELDIR) M=$(PWD) ARCH=arm modules test_capture: test_capture.c bash ./ARM-Linux-GCC-4.3.2.sh $(CC) -Wall -std=gnu99 -O3 test_capture.c -o test_capture #-I$(KERNELDIR)/include set_parameters: set_parameters.c bash ./ARM-Linux-GCC-4.3.2.sh $(CC) -Wall -std=gnu99 -O3 set_parameters.c -o set_parameters tiff_capture: tiff_capture.c bash ./ARM-Linux-GCC-4.3.2.sh $(CC) -Wall -std=gnu99 -I$(TIFFDIR)/libtiff -L$(TIFFDIR)/libtiff/.libs -O3 tiff_capture.c -o tiff_capture -ltiff -lz -lm #-I$(KERNELDIR)/include clean: rm -f s3c2440camera.mod.o s3c2440camera.o s3c2440camif.o s3c2440_ov9650.o sccb.o s3c2440camera.ko s3c2440camera.mod.c test_capture tiff_capture tar: tar czf s3c2440camera.tar.gz *.c *.h Makefile endif
Your module is being created with Intel code. Check the instalation of your cross compile. check also if the CC variavel is set to arm-linux-gcc. Check the PATH variavel and see if has included your cross compile path.
#BASE=/opt/FriendlyARM
export CROSS_COMPILE=arm-linux-
export ARCH=arm # Platform architecture
export CC=${CROSS_COMPILE}gcc; echo CC: ${CC}
export CXX=${CROSS_COMPILE}gxx; echo CXX: ${CXX}
export CPP=${CROSS_COMPILE}cpp; echo CPP: ${CPP}
export AR=${CROSS_COMPILE}ar; echo AR: ${AR}
export AS=${CROSS_COMPILE}as; echo AS: ${AS}
export LD=${CROSS_COMPILE}ld; echo LD: ${LD}
export NM=${CROSS_COMPILE}nm; echo NM: ${NM}
export RANLIB=${CROSS_COMPILE}ranlib; echo RANLIB: ${RANLIB}
export STRIP=${CROSS_COMPILE}strip; echo STRIP: ${STRIP}
export SIZE=${CROSS_COMPILE}size; echo SIZE: ${SIZE}
#export PATH=$BASE/usr/local/arm/4.3.2/bin:$PATH
export PATH=$PATH:/usr/local/arm/4.3.2/bin
this objdump info of "s3c2440camera.ko" from "code.google.com/p/s3c2440camera/" that can be successfully insmod in my mini2440-128 : how can we find that it is for arm9 ? root@dab-desktop:/home/dab/project/mini2440/s3c2440camera-r5# objdump -i -m s3c2440camera.ko BFD header file version (GNU Binutils for Ubuntu) 2.20.1-system.20100303 elf32-i386 (header little endian, data little endian) i386 a.out-i386-linux (header little endian, data little endian) i386 pei-i386 (header little endian, data little endian) i386 elf32-little (header little endian, data little endian) i386 l1om plugin elf32-big (header big endian, data big endian) i386 l1om plugin elf64-x86-64 (header little endian, data little endian) i386 pei-x86-64 (header little endian, data little endian) i386 elf64-l1om (header little endian, data little endian) l1om elf64-little (header little endian, data little endian) i386 l1om plugin elf64-big (header big endian, data big endian) i386 l1om plugin plugin (header little endian, data little endian) BFD: BFD (GNU Binutils for Ubuntu) 2.20.1-system.20100303 assertion fail ../../bfd/plugin.c:436 objdump: plugin: Bad value srec (header endianness unknown, data endianness unknown) i386 l1om plugin symbolsrec (header endianness unknown, data endianness unknown) i386 l1om plugin verilog (header endianness unknown, data endianness unknown) i386 l1om plugin tekhex (header endianness unknown, data endianness unknown) i386 l1om plugin binary (header endianness unknown, data endianness unknown) i386 l1om plugin ihex (header endianness unknown, data endianness unknown) i386 l1om plugin trad-core (header endianness unknown, data endianness unknown) root@dab-desktop:/home/dab/project/mini2440/s3c2440camera-r5#
these are warnings of make:
root@dab-desktop:/home/dab/project/mini2440/s3c2440camera-r5# make clean
CC: arm-linux-gcc
CXX: arm-linux-gxx
CPP: arm-linux-cpp
AR: arm-linux-ar
AS: arm-linux-as
LD: arm-linux-ld
NM: arm-linux-nm
RANLIB: arm-linux-ranlib
STRIP: arm-linux-strip
make -C /opt/FriendlyArm/mini2440/linux-2.6.32.2
M=/home/dab/project/mini2440/s3c2440camera-r5 ARCH=arm modules
make[1]: Entering directory `/opt/FriendlyArm/mini2440/linux-2.6.32.2'
CC [M] /home/dab/project/mini2440/s3c2440camera-r5/s3c2440_ov9650.o
/home/dab/project/mini2440/s3c2440camera-r5/ov9650_qcif.h:1: warning:
'ov9650_qcif' defined but not used
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440_ov9650.c:36: warning:
'ov9650_invert' defined but not used
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440_ov9650.c:39: warning:
'ov9650_restore' defined but not used
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440_ov9650.c:117: warning:
'ov9650_exp' defined but not used
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440_ov9650.c:118: warning:
'ov9650_gain' defined but not used
CC [M] /home/dab/project/mini2440/s3c2440camera-r5/sccb.o
CC [M] /home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.o
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c: In function
'update_target_fmt_regs':
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:414: warning:
unused variable 'cicoscctrl'
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:413: warning:
unused variable 'cicrscctrl'
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:412: warning:
unused variable 'cicrctrl'
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:409: warning:
unused variable 'ciprscctrl'
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:408: warning:
unused variable 'ciprctrl'
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:407: warning:
unused variable 'ciprtrgfmt'
'update_target_zoom_regs':
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:580: warning:
unused variable 'cicoscpreratio'
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:578: warning:
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:577: warning:
unused variable 'ciprscpredst'
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:571: warning:
unused variable 'preDstHeight'
unused variable 'preDstWidth'
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:566: warning:
unused variable 'preVratio'
unused variable 'preHratio'
'start_capture':
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:704: warning:
unused variable 'ciimgcpt'
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:703: warning:
's3c2410camif_querycap':
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:1229: warning:
unused variable 'pcam'
's3c2410camif_enum_fmt_vid_cap':
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:1269: warning:
unused variable 'dev'
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c: At top level:
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:152: warning:
's3c2440camif_free_frame_buf' defined but not used
/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camif.c:257: warning:
's3c2440camif_reg_dump' defined but not used
LD [M] /home/dab/project/mini2440/s3c2440camera-r5/s3c2440camera.o
Building modules, stage 2.
MODPOST 1 modules
WARNING: "video_device_release"
[/home/dab/project/mini2440/s3c2440camera-r5/s3c2440camera.ko] undefined!
WARNING: "video_register_device"
WARNING: "video_device_alloc"
WARNING: "video_unregister_device"
WARNING: "video_devdata"
WARNING: "video_ioctl2"
CC /home/dab/project/mini2440/s3c2440camera-r5/s3c2440camera.mod.o
LD [M] /home/dab/project/mini2440/s3c2440camera-r5/s3c2440camera.ko
make[1]: Leaving directory `/opt/FriendlyArm/mini2440/linux-2.6.32.2'
test_capture
CC: arm-linux-gcc
CXX: arm-linux-gxx
CPP: arm-linux-cpp
AR: arm-linux-ar
AS: arm-linux-as
LD: arm-linux-ld
NM: arm-linux-nm
cc -Wall -std=gnu99 -O3 test_capture.c -o test_capture
In file included from /usr/include/string.h:640,
from test_capture.c:10:
In function ‘memset’,
inlined from ‘main’ at test_capture.c:43:
/usr/include/bits/string3.h:83: warning: call to ‘__warn_memset_zero_len’
declared with attribute warning: memset used with constant zero length
parameter; this could be due to transposed parameters
/tmp/cc9mG9j1.o: In function `main':
test_capture.c:(.text+0x4a): warning: memset used with constant zero length
root@dab-desktop:/home/dab/project/mini2440/s3c2440camera-r5# objdump -d s3c2440camera.ko s3c2440camera.ko: file format elf32-little objdump: Can't disassemble for architecture UNKNOWN!
tanx I found that test_capture is in known (not ARM!) format. but as you see I defined paths and exported them
You should use arm-linux-objdump but the result "architeture UNKNOWN" from the objdump says that the code maybe ARM.
root@dab-desktop:/home/dab/project/mini2440/s3c2440camera-r5# objarm-linux-objdump objarm-linux-objdump: command not found root@dab-desktop:/home/dab/project/mini2440/s3c2440camera-r5# arm-linux-gcc -v Using built-in specs. Target: arm-none-linux-gnueabi Configured with: /scratch/julian/lite-respin/linux/src/gcc-4.3/configure --build=i686-pc-linux-gnu --host=i686-pc-linux-gnu --target=arm-none-linux-gnueabi --enable-threads --disable-libmudflap --disable-libssp --disable-libstdcxx-pch --with-gnu-as --with-gnu-ld --enable-languages=c,c++ --enable-shared --enable-symvers=gnu --enable-__cxa_atexit --with-pkgversion='Sourcery G++ Lite 2008q3-72' --with-bugurl=https://support.codesourcery.com/GNUToolchain/ --disable-nls --prefix=/opt/codesourcery --with-sysroot=/opt/codesourcery/arm-none-linux-gnueabi/libc --with-build-sysroot=/scratch/julian/lite-respin/linux/install/arm-none-linux-gn ueabi/libc --with-gmp=/scratch/julian/lite-respin/linux/obj/host-libs-2008q3-72-arm-none-li nux-gnueabi-i686-pc-linux-gnu/usr --with-mpfr=/scratch/julian/lite-respin/linux/obj/host-libs-2008q3-72-arm-none-l inux-gnueabi-i686-pc-linux-gnu/usr --disable-libgomp --enable-poison-system-directories --with-build-time-tools=/scratch/julian/lite-respin/linux/install/arm-none-linux -gnueabi/bin --with-build-time-tools=/scratch/julian/lite-respin/linux/install/arm-none-linux -gnueabi/bin Thread model: posix gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) root@dab-desktop:/home/dab/project/mini2440/s3c2440camera-r5#
also root@dab-desktop:/home/dab/project/mini2440/s3c2440camera-r5# arm-linux-gnueabi-objdump arm-linux-gnueabi-objdump: command not found root@dab-desktop:/home/dab/project/mini2440/s3c2440camera-r5#
