hi Is it safe that I compile/build applications with linux-2.6.32 and then used the produced binary files on mini2440/64MB with linux-2.6.29.4 ? I do not want to change its default system. Also, is there a simple & safe way to get image from mini2440/64MB ? and another simple & safe way to put image to it? regards
linux kernel version for application & host
nobody! in windows it is possible, for example it may compile & build an application in windowsXP and install and run it in a windows98 machine.
Dear Majid, About application, I think we can run binary compiled from 2.6.32.2 machine on another 2.6.29.4 machine. Except for device drivers, you should use same kernel source as target machine to compile. Regards, Narongrat
