Hi, I'm in big trouble. Not sure what I did but my mini2440 stopped working. NOR still works of course. I'm trying to reinstall supervivi and new versions always fail to find the linux kernel. The problem is on my dvd there is an old version from 2008 which fails to find my NAND device (Its a hynix chip!!). So now my question: Could you please look in your mini2440 files if there are any older supervivi version.? I'm searching for an image with about 160kb size, the oldest one I have is 120kb. Could you have a look please? I'm also downloading an old dvd but it takes ages! thanks in advance!
I need a supervivi version
I have 125K and 251K versions. By "NOR still works", you mean the Supervivi bootloader works but you haven't got the right version of Supervivi to place into NAND? Could you extract Supervivi out of NOR using JTAG and then place that into NAND? Never had to deal with issue, so may not be the right procedure. Good luck
