Hello, inside the .bin file that I flashed to my mini2440 I found a folder with some demo apps. One of them is in picture below : http://www.eyegps.gr/images/buttons.png After all the wiring, this app is working proving that all my connections are OK. Does anybody know where can I find the source code of this app ? I want to use the buttons of mini2440 but I dont know the way. I am using Visual Studio 2005/2008 with VB.NET Thanks
mini2440 Button Control
Several previous posts ? This forum or somewhere else ? ...and I thought friendlyarm was an open project. Either way, thanks for your answer.
The FriendlyARM examples from Qtopia and WinCE are closed-source. http://www.friendlyarm.net/forum/topic/1589 http://www.friendlyarm.net/forum/topic/1152
Hello PhillipMorris, On my website (http://www.domodom.fr/spip/A-GPIO-driver-for-mini2440.html?lang=en), you can find a gpio driver and some samples to use it (c#, vb.net and c++). It is pretty the same mecanism, with available source code. Domodom
Hello Domodom, I have already tested an image of WinCE with your driver build in. Everything is working perfect and I thank you for it. Without your help, mini2440 would be useless for me. It is obvious though that this button application is NOT using your gpio driver. So, I was wondering if there is another way to handle buttons. That's all. My new problem now is that I cannot change the bootlogo image. Do you know I way to put it directly to the image ? Or I have to do it only with DNW.exe ?
Hello, Ok for the gpio, i understand. One day, when i have time, i will update my driver to add a missing functionnality : the possibility to manage the inputs with interrupts. I wrote and test a first version, but i don't have time for the moment to finish it to publish it. Concerning the bootlogo image, is it not possible with DNW and the bootloader ? (via the bootloader menu ?). I never done that... domodom
Thanks for your answer. I finally did it by using an application that I found called StartLogoMaker. It produces a StartLogo.c file generated from a bmp/jpeg. I just replaced this file with the one inside the BSP of WinCE and rebuild the image nk.bin Now I have a mini2440 with my brand on it. My new problem is that the screen is closing after a while (like a screensaver) and I have to touch on it again. How do I disable this ?
