Did anybody have any experience with step motors connected to the Mini 2440 ?
Step motor in mini 2440
You can send data to the stepper motor controller via the serial port. The easiest way is to get an adapter for the ttySAC1 port and use that port. Under the FriendlyARM tab there is an app called "Serial Port Assistant". You can use that utility to write to the serial ports. It will not work with ttySAC0 (the default port) unless you can figure out how to turn off the debug console first. james h
I design a relay board (1 relay) that connects to one of the GPIO port. Can I use it to driver the step motor ?
Probably not directly, you have to use a transistor or any gateway. How you use the GPIO? Using linux with precompiled Kernel? Because my original Kernel has no GPIO support which is rubbish.
I didnīt interfae the relay board to the mini 2440 yet but I did it with tne ATSAM7256 and works fine. The relay board has an Input AC onnector annd an outupt AC connector connected by a relay. Whatever i write 1 to the GPIO the relay lets the pwoer floes frm input to the outupu ac. When I write 0 to the PIO it cuts the power. I mainly use it to open/close a turntile for access control
